UX Models (2019-present)
Driver's seat memory not working
Old Jan 2, 2020 | 01:27 PM
kok8's Avatar
kok8
Default Driver's seat memory not working
I am presenting (in my very poor English) the problem and solution i found (See thisthread), the problem was provoked by me since i tried several times the wrong way to set memories, i used the procedure in English Manual page 200 "Recording a driving position into memory" the wrong way instead of applying the steps in Accessories mode - Power Switch to On (Press twice the Start button Without depressing the brake) i applied them wile engine was running!
The result was that memory recalling did not work, only the Hand Up Display worked with the seat settings not working.
I was fortune enough to find the way to reset the Memories:
1. Move seat to limits, Up, Forward, Reclined (BACK).
2. Save Settings in memory 1. {Shift Lever is in P, Power Switch to On (Press twice the Start button Without pressing the brake), Press "SET" button and then press button "1"), see Manual page 200 "Recording a driving position into memory"}
3. Move seat to desired position and the steering wheel, outside rear view mirrors and head-up display as well.
4. Save Settings in memory 1 {Shift Lever is in P, Power Switch to On (Press twice the Start button Without pressing the brake), Press "SET" button and then press button "1"), see Manual page 200 "Recording a driving position into memory"}
Now everything is working like it supposed!
Old Oct 29, 2021 | 12:53 PM
vegasgs400's Avatar
vegasgs400
thanks for your posting, I will give it a try. thanks again
Old Oct 29, 2021 | 01:04 PM
vegasgs400's Avatar
vegasgs400
it works. THANK YOU
to recall the memory, i have to press n hold the set button for 2-3 secs.
njes300
Jul 17, 2013 06:55 PM
nimit1234
Feb 27, 2006 05:24 PM
p34m23
Nov 15, 2005 08:17 PM
RIPP7399
Aug 20, 2003 01:08 PM
Bentley1
Jan 21, 2003 02:13 AM
