View Poll Results: Do you experience hood flutter/flapping in your TX at highway speeds (60+ MPH)
My hood flutters but I HAVE NOT brought it up with a dealer
36.84%
My hood flutters and I HAVE brought it up with dealer
15.79%
No flutter/flapping
47.37%
Voters: 19. You may not vote on this poll
26’ Lexus TX 500h - hood flutter/flapping
Hello,
first time poster here.
hoping this community can help me figure out a recourse.
Initial inquiry with dealer was met with hood latch and bump stop adjustment.
Further attempts to bring this issue up resulted in “no fault found”.
I’m in discussion with Lexus customer engagement team and the selling dealership on a hood flutter problem.
I can see the hood start to vibrate at 50mph and onward, with it being really bad at 80mph.
Dealership went on ride along and saw the problem as described.
Dealership and customer engagement team both have determined this is normal design.
Asking owners here to see if you have noticed this flutter/flapping issue.
I experienced this also under the same conditions as you described. My remedy was to adjust the round disks in the engine bay that the hood sits on by twisting them to raise them so they fit snug when closing the hood. Took a couple of times to adjust but no more hood flutter.
Hello,
Hello,
Hmm. No flutter in the hood of my 2026 TX500h FSP. (3,200 miles). I suspect what other have commented on - that either the hood is not properly latched down on BOTH sides or the hood bump stops are not BOTH adjusted to be tight against the hood when closed, n your TX500h. Generally they are adjusted via a bolt at the base of each stop.
Hello,
As mentioned in previous comments......have to make sure hood is adjusted to the right spacing with the two round black adjusting disks on the right and left front sides and that you shut hood firmly, dropping its dead weight......
I think its beyond an adjustment issue. First the discs were adjusted too high which made the hood proud of the adjacent panels - the alignment was NOT Lexus quality. AND, the flutter was actually a bit scary - I thought the hood might fly open. I actually stopped at roadside to double check the hood was latched. First, the solution was to lower the discs. This aligned the hood with the surrounding panels and stopped MOST of the flutter. However, I still have some flutter at highway speeds.
Most of the flutter I still see is closer to the windshield than it is to the grill. When you look at most hoods, they have ridges - usually running front to back - that reinforce the hood. They provide strength and I would suggest, reduce or eliminate flutter and flex. This hood has no ridges, it is a slightly rounded but generally flat hood which is a poor design. Very surprising that Lexus wouldn't have seen this possibility from the beginning.
