TX Models (2024-present)
TX350 oil change intervals
Old Nov 11, 2025 | 12:23 PM
TxTom's Avatar
TxTom
Default TX350 oil change intervals
Lexus says to change oil in the TX350 every 10K miles. Why would someone doubt that is not often enough? Just asking.
Old Nov 11, 2025 | 07:21 PM
BayeauxLex's Avatar
BayeauxLex
@tinmanwpk 🍿 👀 here we go again
Old Nov 12, 2025 | 06:40 AM
dmanb2b's Avatar
dmanb2b
It's a recommendation. There is nothing wrong with doing it more frequently other than the additional cost with a trade off of maybe extending the life of the vehicle which only comes into play if you are determined to drive it past the 150k mile mark. That said, I always cut the factory recommended interval in half. Just makes me feel better with no evidence of any benefit. YMMV
Old Nov 12, 2025 | 08:50 AM
tinmanwpk's Avatar
tinmanwpk
Most of us will probably change oil every 5000 miles, some even at 3000 - 4000. I just asked a question about 20weight oil recently and boy oh boy did that one take on a life of its own! This forum is basically enthusiasts who care about their cars, so most, including myself, will not approach 10,000 mile oil change intervals. I will go 5000 and change. There is no "right" answer, but some are better than others.
Old Nov 12, 2025 | 11:49 AM
Framestead's Avatar
Framestead
Lexus gives you a warranty manual. It lists reason when the 10k oil change does not work. Compare your driving habits, select a duty cycle, and choose which oci is appropriate guided by Toyota engineers.
Some folks do a break in oil change early, as plenty of owners get unnerved when they see machine debris/metal flakes in the first oil change, particularly in the filter. Nothing abnormal, as new engines always have some level of debris, and the filter is doing its job if you see debris in the media specifically. Toyota's official guidance on the matter dont fear, let it run, but up to the owner.
Old Nov 13, 2025 | 03:09 PM
coolbrazz's Avatar
coolbrazz
I don't even drive 10k in a year anyway. I change mine once a year which is around 6k miles.
Old Nov 14, 2025 | 10:57 AM
LawyerRon's Avatar
LawyerRon
7th Gear
5,000 is what I use on all my vehicles. 10,000 miles is fine if you just want to make it to the end of the warranty or around 100,000 miles. 5,000 miles has been shown to sludge up engines.
Old Nov 14, 2025 | 12:40 PM
tinmanwpk's Avatar
tinmanwpk
"5000 miles has been shown to sludge up engines."
Where is backup for this please?
Old Nov 14, 2025 | 02:37 PM
LawyerRon's Avatar
LawyerRon
7th Gear
Depends on how long you're keeping the car. If you keep your car for around 100,000, no sweat. But the next owner won't like you. Lots of youtube videos on this from mechanics showing sludged up engines on disassembly or cameras through the valve cover. Especially the one from "The Car Care Nut". He worked for years as a certified Toyota mechanic at Toyota dealers and now has his own shop. He recommends AGAINST the practice of the 10,000 mile oil change. He's disassembled well- maintained Toyota engines using 5000 mile change intervals at 200,000 miles and they look like new inside. The 10,000 mile interval engines will show lots of sludge at 200,000 and often require replacement. Toyota/Lexus will easily go 200,000-to 300,000 miles with good maintenance.
Do what you want but I believe oil changes are cheap and engines are expensive.
Old Nov 14, 2025 | 02:40 PM
LawyerRon's Avatar
LawyerRon
7th Gear
CORRECTION:
Actually, I posted the wrong interval; I meant to say 10,000 mile oil change intervals has been shown to sludge up engines.
Apologies all round!
Lend27
NX - 2nd Gen (2022-current)
17
Jul 2, 2025 03:58 PM
rmgmag
RX - 5th Gen (2023-present)
20
Jun 20, 2025 03:48 AM
ChicagoGSf
Jan 9, 2021 11:13 AM
THoon
Aug 2, 2007 03:55 PM
