TX Models (2024-present)
OTA update?
Old Jun 4, 2025 | 05:18 PM
Bluemus's Avatar
Bluemus
Default OTA update?
Has anyone received an over-the-air update through their multimedia system? I've owned my TX since Jan 24 and have never seen one (and the system says there isn't one), which seems like a long time, and I just want to make sure that I'm not missing an update because my vehicle isn't able to retrieve them for some reason. Thanks for letting me know.
Old Jun 5, 2025 | 01:07 AM
jhosche's Avatar
jhosche
6th Gear
I've had mine since Oct 23 and I recall one OTA update since then. Don't remember exactly when it happened, just that there was one.
Old Jun 5, 2025 | 06:58 AM
Bluemus's Avatar
Bluemus
Ok, thank you for letting me know.
Old Jun 5, 2025 | 09:15 AM
sandlot9606's Avatar
sandlot9606
You can comb through all the L-SBs but I think this was the only multimedia update released to fix a ton of bugs https://static.nhtsa.gov/odi/tsbs/20...05178-0001.pdf
Lexus has a pretty convoluted way to manually check via their website and usb drive too: https://www.lexus.com/firmware-updates/
Old Jun 5, 2025 | 10:37 AM
Bluemus's Avatar
Bluemus
Thank you. I don't recall seeing this update. Perhaps, the dealer installed it when I came in for service. The USB method doesn't seem to work on the TX or at least not mine. Maybe because it's a usb-c port?
Old Jun 5, 2025 | 11:07 AM
sandlot9606
get a usb-a to usb-c dongle or get a usb-c thumb drive
Old Jun 5, 2025 | 12:11 PM
Bluemus's Avatar
Bluemus
I tried connecting a usb-c external drive, but this didn't work. Does it need to be a thumb drive specifically?
Old Jun 5, 2025 | 01:39 PM
sandlot9606
I doubt it, what format is your external?
I believe it requires fat32 and 2+ gb capacity
I followed the directions and it wrote a 024655db_update_by_usb.json file on my drive
Old Jun 5, 2025 | 03:27 PM
Bluemus's Avatar
Bluemus
The only two formatting options on my computer appear to be NTFS and exFAT (see attached picture). It's currently exFAT, 119GB.
Old Jun 5, 2025 | 03:32 PM
sandlot9606
I don't think those will work. MacOS can do it or might be windows apps that can convert it for you.
Someone else made this nice post also saying ntfs and exfat aren't compatible with lexus multimedia: https://www.clublexus.com/forums/sho...errerid=433832
Old Jun 5, 2025 | 03:35 PM
Bluemus's Avatar
Bluemus
When I follow the instructions on Lexus' website, I don't see [Output info to USB memory] in the Software update menu window.
I've attached a picture of what I see in this window when I have my USB drive inserted.
Old Jun 6, 2025 | 07:59 AM
Bluemus's Avatar
Bluemus
Thank you for the information you shared. I was able to get the drive to work using the software suggested in the link and to check the software version, which turned out to be up to date.
The usb-c port certainly made checking the software version manually much more challenging.
Old Jun 6, 2025 | 08:20 AM
sheetmetalfab's Avatar
sheetmetalfab
Old Jun 6, 2025 | 10:53 PM
sandlot9606
gotta make sure ur drive meets these requirements:
USB communication format: USB 2.0 HS (480 Mbps)
File format: FAT16/32 (Windows)
Class: Mass storage class
Old Aug 10, 2025 | 10:42 PM
Muse5381's Avatar
Muse5381
4th Gear
You may be missing the regular FAT32 option because your drive is too large. You need to stick to a drive at or below 32GB for a more consistent experience of getting your OS to show the FAT32 option.
ZaiKur
ES - 7th Gen (2019-2025)
Mar 31, 2025 10:08 PM
JKING3
Jan 26, 2025 05:44 AM
Feb 1, 2021 04:08 PM
TigetJacks
LS - 5th Gen (2018-present)
15
Nov 17, 2019 02:03 PM
seangkim
NX - 1st Gen (2015-2021)
Jul 24, 2019 09:49 AM
