TX Models (2024-present)
CX Axle - CV Joint Failure
Old Nov 2, 2024 | 10:50 PM
2threp's Avatar
2threp
Default CX Axle - CV Joint Failure
My TX500h Luxury has 27k miles and the CV joint or axle is failing. It began to click when accelerating and turning, and this started after around 20k miles. I have an appointment this week for evaluation and repair. Anyone else?
Old Nov 10, 2024 | 05:00 PM
mikemu30's Avatar
mikemu30
perhaps the boot became compromised, punctured from some road hazard.
Old Nov 10, 2024 | 07:10 PM
2threp's Avatar
2threp
Could be. I’ll learn more Thursday when I take it in to the dealer. That said, it appears to be a known issue. I’m seeing a number of posts about it on the Grand Highlander forums.
Old Nov 11, 2024 | 01:17 PM
E46CT's Avatar
E46CT
all you'd have to do is turn the wheel to the left (or right) and look with your eyes to see if any damage or grease leaking. it's a tall vehicle so plenty of space to look.
Old Nov 11, 2024 | 01:46 PM
2threp's Avatar
2threp
The joint or axle is definitely bad, with it being under warranty I’m not too concerned about sorting out which. Also getting the recalled airbag repaired as well as a couple other small items.
Old Nov 21, 2024 | 11:21 PM
2threp's Avatar
2threp
Picked up my TX today after 7 days at the dealer. The installed a new axle and it seems they weren’t entirely sure what the issue was. It seems better for now.
Old Feb 23, 2025 | 01:18 PM
2threp's Avatar
2threp
32,000 mile update - CV Axle is bad again, and will need to be replaced. I chose to wait for an updated or improved axle. Lexus said the 350 has already received a “fix”, but there is not one yet for 500h. I’ll wait with the bad axle until the new/improved axle is released for 500h.
Old Feb 24, 2025 | 02:27 AM
jhosche's Avatar
jhosche
6th Gear
Yup, happened with mine closer to 15k miles. They weren't surprised at all, had a bulletin all ready to go on the repair, etc
Old Feb 24, 2025 | 06:37 AM
2threp's Avatar
2threp
Which model do you have? Has it happened again?
Old Feb 25, 2025 | 04:14 AM
jhosche's Avatar
jhosche
6th Gear
Mine is just a 350, but I'd be surprised if the hybrid used different parts for this.
My dealer mentioned that I was the 6th repair they had for this issue.
Old Feb 25, 2025 | 05:04 AM
2threp's Avatar
2threp
Dealer said the 500h has a slightly different axle and that there isn’t a fix yet. Fewer 500h out there, I guess. Thanks for your feedback.
Old Apr 7, 2025 | 06:56 AM
Steph1220's Avatar
Steph1220
3rd Gear
Default Humming noise after Tx350 axle replacement
My front axles had the clicking noise and were both replaced at around 6k miles. Has anyone else had a humming noise that replaced the clicking, after the axles were replaced? This occurs when turning left or right.
Old Apr 7, 2025 | 07:36 AM
2threp's Avatar
2threp
Which model do you have. I haven’t noticed a hum. Thanks for the feedback.
Old Apr 7, 2025 | 08:01 AM
Steph1220's Avatar
Steph1220
3rd Gear
I have the 2024 tx350. I think they figured it out though. When they installed the new axles, they must have bent the backplate. So when i was turning, the plate was rubbing on the rotor.
i have also been told that they are now replacing the gas door thing totally
Old Apr 7, 2025 | 08:33 AM
2threp's Avatar
2threp
Thanks for the additional feedback. That is what I heard about the 350, unfortunately it appears that parts are slightly different for the 500 and I haven’t heard that there’s a fix in yet. Glad to hear they figured out your other issue. That’s good news about the fuel doors, I have had a few occasions where I couldn’t get it open.
