Who really know's offsets on a sc300???
Old 02-03-06, 09:14 PM
flossn
flossn's Avatar
Default Who really know's offsets on a sc300???
I've seen a lot of SC's that are running 295's (mostly on 18x10's) and i'm wondering if there is enough room to run a 305/35/18? Actually i'm convinced there is since i've seen 315's (on a 17x11rim) It's just a matter of proper offset. Can anyone help with the proper offset to do this? I would prefer the rims are flush with the wheel well and no wheel well mods, although rolling would be ok if needed.
A 18x10 is wide enough for this tire size (some will disagree but i'm reading it right off of nitto's website, so please don't tell me to run a 265 ). Does anyone know what offset would be the best to run 305's? Any help would be appreciated!!
Tony
Old 02-05-06, 11:26 PM
WebStarr
WebStarr's Avatar
I'm not sure of the exact offset you'll need, but it will have to be high: like between +45 and +50. Right now I run an 18 x 10 +42 on a 275/35-18 and it rubs slightly over big bumps. I need to roll my fenders a little bit. You will definitely need some fender rolling. Instead of going with a 35 series tire, try going with a 305/30-18. It's closer to the factory diameter.
Old 02-05-06, 11:45 PM
AME_VIP
AME_VIP's Avatar
I'd say around 18x10 +45. You don't want the tire to hit anything on the suspension.
I had 18x9.5 +40 with 285/35/18 with rolled fenders and it was no problem.
Old 02-06-06, 09:06 AM
SoCalSC4
SoCalSC4's Avatar
305/35-18 is a cool size, but it's pretty big for an 18x10" wheel. It would fit better on 18x11.
It's difficult to say if (for example) the 305 would 'clear' the fender with 18x10 +45 or +50. The 305 will be quite a bit wider than the wheel, so were a 285 or 295 would clear, the 305 may not due to the additional sidewall bulge.
I would go as far as a 315 on an 11.5" wide wheel on the SC... I'd use 18x11.5 +45, but I like my wheels aggressive.
(and I am good at modifying fenders).
I'm always amused that people want to push the envelope with tire sizes and then want "no mods and no rubbing." You know all those cool looking Japanese VIP and European cars with crazy looking wheel fitments? They ALL have modified fenders!
Old 02-06-06, 09:58 AM
flossn
flossn's Avatar
Yeah i don't mind rolling the fenders if i have to i just wanted to hear what can be done on a stock wheelwell or close to it. I will most likely be going with the HKS drag coilovers which from what i've read should provide a little more space back there. At least i will be able to adjust the height accordingly if it's rubbing bad. I guess i'm more concerned about just getting the proper offset so i don't hit the suspension or have the wheel sticking out a lot.
Do you think a 315 on a 18x11.5 would stick out past the fenderwell on a +45? I think BFG has a drag radial in that size, hmmm..
Sounds like everyone agrees on the offsets, some good info here,
Old 02-06-06, 02:34 PM
WebStarr
WebStarr's Avatar
You will definitely need fender mods to do 11.5 +45 with a 315 tire. I can only advise you based on my personal experiences, and based on my own rims and tires, 10" wide +42 on a 275 tire. As I stated my tires rub slightly. The setup you mentioned would stick out an additional 16mm more than mine. And that's just the rim, the tire is wider than mine too. I need a slight roll. You will need roll and maybe a pull. 315 is a mightly wide tire.
Old 02-06-06, 03:04 PM
D2-AUTOSPORT
Former Sponsor
D2-AUTOSPORT's Avatar
sound cool on the specs, just be careful on those BFG tires they run VERY big (sidewall size, etc)
Old 02-06-06, 03:37 PM
flossn
flossn's Avatar
Really? Interesting. I'm looking at the Nitto dr's vs the BFG dr's and i've hear the nittos run small for what their size says they are and that they also don't hook as well when cold but that's another thread altogether, lol
So do you think a 18x10.5 with a +45 with a 305/30 bfg would work out? Nitto only has a 305/35 which sounds like it might cause more problems. Oh and do you carry volks?
myroncuz
08-09-16 02:15 AM
NCDUB
07-26-09 04:39 AM
mikez
02-12-09 04:57 AM
CP_Ree
02-12-05 08:41 PM
redgs4
04-30-02 12:48 PM
Quick Reply: Who really know's offsets on a sc300???
