Suspension Springs, shocks, coilovers, sways, braces, etc.
Defective struts
Old 07-13-18, 09:49 AM
Kathryno
Kathryno's Avatar
Default Defective struts
I have a 2013 GS350, FL strut went bad at 27,000 miles. Dealer replaced under warranty.
RL strut just went bad at 40,000. Warranty expired, waiting to hear from corporate to approve with they will fix for free.
Has anyone else had problems with their struts going bad at low mileage? Struts are suppose to last for 100,000+.
Mild manner driver
Old 07-13-18, 10:02 AM
Davenlei
Davenlei's Avatar
Mild manner driver
Yes both my front struts went out prematurely. The front left went out around 23K miles and the left front strut went out around 35K miles. Both were fixed under warranty but in all the cars I have ever owned, I have never had failures this early and often. My car is stock height and no suspension modifications.
I also had a left front wheel bearing go out at 25K miles. I had to take it in three times because they kept claiming it was my tires. I switched my tires and the noise was still there so when I took it in the third time , a master tech drove my car with me in it and within 1 minute said :"Yep, that is definitely a failed wheel bearing. Sorry you had to bring it in so many times for this."
Old 07-13-18, 01:51 PM
np20412
np20412's Avatar
Mild manner driver
100k+ is very optimistic for stock struts to maintain their initial quality. I'd say something more like 75k can very reasonably be expected though.
AS long as your dealer/Lexus will cover this you should be OK on the new set for years to come. I would think Lexus should cover it since you're just ever so slightly out of warranty (time wise, not even mileage wise) and your vehicle has a documented history of this same issue albeit on the front.
Old 07-15-18, 10:54 PM
Davenlei
Davenlei's Avatar
Just to add onto my earlier comment about two of my struts going out very early on my GS350. I also have a GX470 with 150+ K miles on the original struts and they are still performing within spec (not like brand new but are performing well). I have read and been told by service people at the dealers to never let my GX470 go because they are practically bulletproof and were very over-engineered. I bought my GX470 at 28K miles on it and the only thing I have ever had to replace out of the regular service/maintenance items was the alternator at 135K miles.
Old 07-23-18, 01:29 PM
Davenlei
Davenlei's Avatar
Just checked my struts and my rear drivers side is leaking now.
Old 08-11-18, 04:44 PM
DiezDos
DiezDos's Avatar
Were you by chance hearing a clunky/knocking sound from that corner? When turning and at bumps and dips..
Reason I ask is because I have been trying to identify what is a sound coming from my car and my strut is the next thing I want to check.
Old 08-16-18, 02:09 PM
ReggieFish
ReggieFish's Avatar
I've been having an issue hearing a squeaking noise when ever I'm going over mild bumps at low speed.
Old 11-28-18, 02:02 PM
Jebsmith
Jebsmith's Avatar
Left front stock KYB strut is leaking on my 2015 Gs 350 with only 31K . Seems to drive ok.
Old 12-10-18, 03:53 AM
peasodos
peasodos's Avatar
Received 2,226 Likes on 1,450 Posts
86k stock structs no problems, used to have a 1998 Honda accord 232k never had an issue with stock struts.
I guess if you have bigger rims and stiffer shocks your more susceptible to premature failure, because the suspension takes more of a beating.
Old 12-15-18, 09:15 PM
richard203
richard203's Avatar
any1 know where to buy the kyb extage? my 4 shock is leaking. im at 70k mile only hopefully these will last longer than oem ones. ><
Old 12-17-18, 01:56 PM
timmy0tool
timmy0tool's Avatar
is this for fsport or non-fsport?
Old 04-12-19, 11:00 AM
blpolk79
blpolk79's Avatar
I know I'm late to the party, but I bought a used 2013 GS 350 F Sport AWD and recently had the right rear strut/shock go out and my bumper to bumper says it's not covered since it's not the strut assembly. How'd everyone get Lexus to cover it?
Old 04-15-19, 09:17 PM
lbcgav
lbcgav's Avatar
What the hell does that mean? Your springs have to go bad at the same time?
Old 04-30-19, 02:48 PM
Majic24
Majic24's Avatar
Mild manner driver
These struts are not performing/lasting very well. Had to replace both of my front struts with just over 36,000 miles, one was leaking but best to replace in pairs. My friend has RX 350 with around 100,000 miles and front struts just replaced. Any ideas why failure with such low miles and others having same issue?
PDXLex
21
12-01-22 09:45 AM
Davenlei
09-20-17 04:20 PM
artbuc
05-18-16 06:41 AM
99lexus
05-28-07 03:10 PM
pgpanos
Hybrid Technology
03-20-07 11:43 AM
Quick Reply: Defective struts
