This kit will fit Lexus GS350 and GS460 from 2006+. You are looking at one of the finest made coilover kits available. The NEX Type GT kit has all the features of a racing coilover without the harsh ride and cost. The NEX Type GT is designed to allow the vehicle to be lowered without affecting shock stroke or spring preload. This is done by separating the spring preload adjustment from the ride height adjustment. As a result of this unique design, the ride quality is not affected by ride height! This is only found on a few kits! Adjustment range is for the front is 1.5"-2.5" and the rear is a 1.5-2.5" lowering.
The GT kit features 4 position adjustable shock damping
I am lowered ~ 2" on springs also and the drop is almost perfect. 2.5" drop would be more then enough if you ask me and be a daily driver unless you want to get crazzzy.
Maying's drop is dead on for me. That is where I would sit if I was on coils. Only thing the springs dont have is the drop in the front sitting a little more flush but I have a hard time going up and down my driveway so that was my decision also.
getting so much mixed reviews about the Nex GT and SS sigh... not sure if i should just save up for good/expensive coils..... =(
Its a simple choice. Do you just want a drop, or do you want to be slammed? Furthermore, do you want performance? If you want to be slammed and hit the curves & corners hard get JIC's. You get the best of both worls. If you just cruise and chillax, get the Megans or Nex's. You can be slammed literally to the ground, but youll suffer on the performance side But at the end of the day you drive a GS, how fast are you gonna be driving it on a daily basis? But if you got the money then get the JIC's. I will be picking up a set soon, reason I have the NEX's is experimental. Ive had the Teins, Megans, and now NEX's and they all have their up and downs.
