Suspension Springs, shocks, coilovers, sways, braces, etc.
GS AWD (lowered suspension data)
Old May 18, 2011 | 12:52 PM
  #451
IXI187IXI's Avatar
IXI187IXI
exactly which is why im lead to believe i did it wrong the first time since the shop took some exact measurements for me.
Old May 18, 2011 | 04:48 PM
  #452
Kcook700's Avatar
Kcook700
Sounds good. If you can, take a pic or two once installed so we can get a better idea of how it looks installed.
Old May 20, 2011 | 08:50 AM
  #453
derfp2's Avatar
derfp2
I "C" more damage coming....
Old May 20, 2011 | 08:55 AM
  #454
derfp2's Avatar
derfp2
the front axles need some play to work properly...if u make it so that theres no "play" during suspension travel, ur gona have some serious expensive damage when u hit ur first large bump/dip....
Old May 23, 2011 | 08:00 AM
  #455
IXI187IXI's Avatar
IXI187IXI
im not removing any play in the axles, all im doing is lining everything back up so its not stretched out on an awkward angle when is lowered.
Old May 24, 2011 | 11:10 AM
  #456
imadesign's Avatar
imadesign
found a topic from google,, is this the same case that you are trying to fix
Originally Posted by GOOGLE
Here is a pic of the CV bucket and the "spider" (the set of 3 roller bearings that go in the CV bucket).
When the car is new the spider rides on a smooth surface in the CV. But as time goes on it makes a wear spot. This starts to happen by around 20k miles or so (this is very rough estimate based on folks who have complained about the vibration after lowering). The pic below shows what the wear spot looks like:
When you lower the car, it moves the spider to a new spot where it normally rides. Based on the geometry, the new spot is very close to the old spot. The vibration is caused by the spider sliding over the edge of the new spot into the old spot. It trammels back and forth there..
Old May 26, 2011 | 07:30 AM
  #457
leonsup's Avatar
leonsup
...and I assume a "new" CV bucket is not an option? Pricey?
Old May 26, 2011 | 07:32 AM
  #458
IXI187IXI's Avatar
IXI187IXI
it has to do with that. i posted information on this way back in this thread in regards to the S2K guys
Old May 26, 2011 | 11:07 AM
  #459
imadesign's Avatar
imadesign
im thinking of doing it, but dont you think that this is going to add more stress to the bearing causing it to fail prematurely?
correct me if iam mistaking, the spacer fits between the bearing and axle?
Old May 26, 2011 | 02:17 PM
  #460
dll5007's Avatar
dll5007
has anyone looked into "roll center adjusters".
http://www.maxrev.net/site/index.php...sion&Itemid=58
Old Jun 6, 2011 | 01:08 PM
  #461
Kcook700's Avatar
Kcook700
Actually that is an option. Essentially all that needs to be done is extend the length of the axle (at least, that is what the hypothesis is) 187 is doing this by adding a "spacer" in between the axle and the wheel knuckle. If proven, there could potentially be several ways to accomplish this. Custom CV buckets, spacers, custom axles, etc. It all depends on how much you are willing to spend, time, and resources..These spacers would be easy to install and easily mass produced.
Old Jun 6, 2011 | 04:23 PM
  #462
Kcook700's Avatar
Kcook700
any by far the cheapest. i already worked out pricing with a machine shop for quantities.
Slangin' spacers? What are we talking a set?
Old Jun 13, 2011 | 08:01 AM
  #463
IXI187IXI's Avatar
IXI187IXI
Alright new spacers on and took it for a quick drive with the guy. Vibrations have decreased a lot from what I could notice in that 5 mins. Having the car aligned now to get everything squared away. Hopefully no more lights on the ride home. I should have better input after I take the 45 min drive home.
The problem the first time was it was not centered. We had them in the right location just not centered. We had to temp. hold it in place while the axle went back in. Now with everything tight it shouldn't move. I could possibly come up with a more elaborate design for the spacers so you don't have to temp hold them in place but I'm sure the cost would probably triple.
We tested the wheel once it was installed and spun it and it wasn't hitting or rubbing on anything, so I'm keeping my fingers crossed for the ride home.
Old Jun 13, 2011 | 08:11 AM
  #464
Kcook700's Avatar
Kcook700
3M double sticky tape is that expensive?
Old Jun 13, 2011 | 08:18 AM
  #465
IXI187IXI's Avatar
IXI187IXI
Ha I meant more elaborate so you don't have to temp hold it in place. We just used tape to hold it centered and slide it back in. Pretty easy and it only takes about 10 mins per side to install. Just need a 30mm socket for the axle nut.
