Rear speed sensor replacement
Old Oct 15, 2021 | 02:52 PM
Kjoy28's Avatar
Kjoy28
10th Gear
Default Rear speed sensor replacement
Does anyone know how you get to where the rear passenger ABS speed sensor connects? I wasn’t sure if you have to remove the whole quarter panel or what. I sure hope not!
Old Oct 16, 2021 | 12:29 PM
Sasnuke's Avatar
Sasnuke
I've attached the instructions as a PDF.
No idea what vehicle you have, so the instructions are for a 2014 IS350...they should all be the same when it comes to the rear sensors.
The instructions encompass both left and right...you can skip the first step of disconnecting the battery...just make sure the car is turned off.
File Type: pdf
Old Oct 17, 2021 | 11:40 AM
Kjoy28's Avatar
Kjoy28
10th Gear
I have a 2015 IS250 RWD model, these should work fine though. Thank you
danotheman
Apr 4, 2021 01:55 PM
Aapost
Aug 2, 2019 07:50 AM
BlackRX300
RX - 1st Gen (1999-2003)
31
Jun 12, 2016 10:53 AM
lexsc3
Aug 24, 2010 10:44 PM
MATEOGS
Aug 6, 2008 08:59 PM
