2006 is350 replacement shocks
Old Aug 20, 2021 | 01:24 PM
ncatona's Avatar
ncatona
Default 2006 is350 replacement shocks
I'm looking for oem or stock height stuff. I've seen kyb from what others used on here, I currently have 150k with probably oem shocks. What have you used for stock height, and what would you recommend? Any bilistein shocks used here?
Old Aug 22, 2021 | 03:16 PM
wakaru8's Avatar
wakaru8
I'm rocking the Bilstein made F-sport shocks here (accessory version). Really depends on what you're going for but sounds like you want to keep it at stock height and ride comfort. In that case, KYB is fine. You could also try to use stock sport suspension shocks. Everything else aftermarket is going to be stiffer, even including ones I'm running.
Old Aug 24, 2021 | 06:51 AM
Gville350's Avatar
Gville350
If I remember correctly, OEM is KYB. So you'll be fine there. I've got KYB currently with H&R springs. Very DD-friendly and actually more compliant than the factory sport suspension.
Old Aug 24, 2021 | 12:56 PM
ncatona's Avatar
ncatona
really kyb is oem!?!? Shoot I gotta go get some asap lolol
Bxtaskforc
Aug 25, 2021 08:04 AM
jbone29
Mar 19, 2013 12:03 PM
autovation
Suspension and Brakes
Apr 24, 2011 10:22 AM
Big Willy
Apr 28, 2010 01:50 PM
