Torque specifications
Old May 23, 2019 | 10:53 AM
Kiai808's Avatar
Kiai808
Exclamation Torque specifications
Im looking for ft~pounds specs on [bolts to differential from axle] 6 bolts total
and [drive shaft yolk to differential ]
thanks!
Old May 23, 2019 | 11:19 AM
captainva's Avatar
captainva
Here you go
Old May 23, 2019 | 02:59 PM
Kiai808's Avatar
Kiai808
Right on man!
Old May 24, 2019 | 11:04 AM
sbagdon's Avatar
sbagdon
Matchmark the shaft to the diff, and validate that you've replaced each crescent-ring and bolt to the very location it came from. This will keep the shafts in balance with the diff.
Old May 24, 2019 | 03:39 PM
Kiai808's Avatar
Kiai808
Thanks , I rebuilt the rear suspension, so exact match to original position will be hard to original DIFF.
Old May 29, 2019 | 02:05 PM
Kiai808's Avatar
Kiai808
How about the stabilizer bracket?
Old May 31, 2019 | 01:50 AM
sbagdon's Avatar
sbagdon
Matching the axle-shaft and propeller-shaft (if possible) to the diff is different then matching the other suspension members to each other... the three shafts are rotating masses. Just as a wheel/tire should be balanced to each other, and a warped rotor can vibrate, the rotating mass of the shafts should also attempt to be balanced.
Rmg93SC
Aug 19, 2017 12:38 PM
Sc3001jzTT
Jul 29, 2010 04:35 PM
LEXMICK
Performance
Jun 14, 2008 02:23 PM
DaemoN
Suspension and Brakes
May 22, 2008 11:03 PM
bpc23
Nov 17, 2006 09:17 AM
