Rough ride. Where to start?
Wondering if I can get some help. I mounted oem Fsport springs with the stock shocks. The springs lowered the car by 1 inch but the ride is horrible. I expected a more stiff and "sporty" ride but it's very harsh. Has anyone else experienced this? It almost seems like the shocks are bottomed out and not dampening the springs at all. My theory is that the standard shocks are at a higher "neutral point" and are not able to dampen properly or at all at the new lower neutral point. Opinions?
Do you have any recommendation for shocks that would fit well with the f sport springs? It is a 350 awd with 19 inch wheels. One other consideration that might have affected the ride is that I mounted the 19 inch wheels at the same time as the springs. I'm thinking that the much larger weight of those wheels could be a factor that the shocks can't keep up with.
unfortunately I don't have any recommendations on that end. 19inch wheels would have definitely made the ride harsher as your tire sidewall must have decreased at the same time. I imagine you're running a 35 sidewall now? heavier wheels will also transfer more force to the suspension/chassis
Looking for a suspension replacement here too! Almost ~70k miles on H&R springs and 137k mile old OEM shocks. Are Megan EZ Streets still a good option? Been neglecting this car for too long and need to get her back up in shape!
@Toxicxk23
If you aren't trying to spend too much money and can DIY the install, check out the $200 coilovers on eBay. I've been riding mine for 14 months and over 10k miles and everything is good considering the costs.
Is much better than my leaking OEM shocks and Tanabe DF210 springs.
https://www.ebay.com/itm/Fit-Racing-Coilover-Suspension-Kits-For-LEXUS-IS250-IS350-ISF-IS-F-GS350-GS430-RWD
@Toxicxk23
When you live in a nice climate (California, Florida) the roads are pothole free, sure maybe that $200 suspension is great. When you live somewhere with rough roads, your suspension has to actually do work. Remember you get what you pay for. $200 suspension is going to probably be worse than stock suspension in terms of ride quality where the suspension actually has to cycle..
ilshm113
Sep 14, 2014 11:34 PM
Lexicious
Suspension and Brakes
Jul 12, 2013 06:08 PM
ToyotaLexus
Sep 24, 2001 05:01 PM
