HELP, Can't remove the rear strut after 4 hours of trying
Old 08-01-18, 11:19 PM
  #31
Tempock
Tempock's Avatar
updated for deletion
Old 08-02-18, 12:24 AM
  #32
Blkexcoupe
Blkexcoupe's Avatar
If they're oem end links then you should be able to use a 5mm hex key to hold them in place and tighten it down with a wrench or if you have a hex socket, then you can use a ratchet to tighten it down while holding the nut with a wrench.
Old 08-02-18, 02:31 AM
  #33
MedicalDoc
MedicalDoc's Avatar
I also managed to drop a nut behind the gas tank, and another nut in the engine bay somewhere. I now only have 2 14mm nuts on the front strut top mounts, so I hope that's ok.
TEMPOCK,
You have to put those 3 nuts back on. Do not just put 2.
The boot is ripped in the last pic. Either source a good one,i.e. previously-enjoyed, or fix that one???
Inside the little boot,on the star--hex--side of the end link, there is a nut you can hold on to, like a previous post stated, but of course it's better to use the hex if possible.
Are the end leaks leaking grease?
Old 08-02-18, 05:57 AM
  #34
logix7
logix7's Avatar
just throwing it out there.. all i did was unbolt the rear brake calipers and use a pry bar to push the hub/knuckle down and there was plenty of clearance to remove the shock. i see my post is a bit late though
Old 08-02-18, 02:23 PM
  #35
Tempock
Tempock's Avatar
Old 08-02-18, 03:02 PM
  #36
SpectraBlu
SpectraBlu's Avatar
sounds metallic. It's 100% not the brakes, the only thing I can think of is the dust shield.
^^^ You're correct, it is most likely the dust shield. Congrats on installing the coilovers yourself
Old 08-02-18, 06:34 PM
  #37
Tempock
Tempock's Avatar
Old 08-02-18, 07:30 PM
  #38
MedicalDoc
MedicalDoc's Avatar
CONGRATS!!!!!
ahornick
11-12-14 10:43 AM
Revoked911
08-30-10 11:33 AM
Suneet
16
07-23-06 01:25 PM
PandaSC300
Suspension and Brakes
09-15-05 05:13 PM
WILB3
09-10-03 01:17 PM
Quick Reply: HELP, Can't remove the rear strut after 4 hours of trying
