Wheel size/offset question
Old Jun 13, 2018 | 12:07 PM
tekmode's Avatar
tekmode
Default Wheel size/offset question
What are the typical offsets people are running?
I'm looking at some wheels in these sizes 19×8.5 +38 / 19×9.5 +38 and was wondering about rubbing or needing spacers
Old Jun 13, 2018 | 03:53 PM
Sasnuke's Avatar
Sasnuke
You should be fine with those specs. Rim design will ultimately dictate if the front will clear the calipers...this would be my only concern with a +38 in the front on a 8.5 rim.
If they don't, then a small spacer should solve the issue.
Old Jun 13, 2018 | 10:50 PM
LexoDAV's Avatar
LexoDAV
It will clear
Old Jun 22, 2018 | 05:53 AM
tekmode's Avatar
tekmode
I was looking at the work emotion m8r
I wouldn't think there would be any brake clearing issues...
Old Jun 22, 2018 | 06:39 AM
Sasnuke's Avatar
Sasnuke
You should be ok with those, of course the rim supplier should be able to confirm fitment.
Old Jun 23, 2018 | 11:03 PM
Thesickest's Avatar
Thesickest
Any idea if 9.5 +32 will fit in the front with a slight drop?
Old Jun 24, 2018 | 07:25 AM
TOPENDMS's Avatar
TOPENDMS
Former Sponsor
9" +32 will fit, but check brake clearance with the wheel shop.
9.5" most likely will not at any offset.
Old Oct 23, 2020 | 11:57 PM
JBPP's Avatar
JBPP
9th Gear
Updating this thread as I recently purchased a set of wheels on these exact specs and my fronts did not clear the brake calipers (wheel design issue).
Tried to install a 5mm spacer and barely cleared the calipers. 2 potential problems though:
1. Will the brake calipers post any contact issues with the wheel as calipers tend to expand when it heats up and
2. Will I need to replace my OEM studs since placing the 5mm spacer lessened the bite of my lugnuts to about 3.5 full turns
Old Oct 24, 2020 | 07:18 AM
Sasnuke's Avatar
Sasnuke
A 1+mm clearance between the rim and caliper is fine...the caliper will never expand that much.
You'll be fine with a 5mm spacer.
Old Oct 24, 2020 | 09:06 AM
JBPP's Avatar
JBPP
9th Gear
Thanks, Sasnuke. Is it safe to say that for as long as the wheel can do a full turn without hitting the caliper, then it should be ok?
Old Oct 24, 2020 | 02:15 PM
Sasnuke's Avatar
Sasnuke
I would say so...you're really looking for a 1mm or more clearance between the caliper and spoke.
Old Oct 26, 2020 | 08:03 AM
350Fsprt's Avatar
350Fsprt
while on this topic, can anyone advise on ideal rim size/offset for 18" rims while on rsr downs?
I currently only use my stock wheels(18") but I'm using spacers, and looking to switch to a set that wouldn't require spacers, and still not rub/ and look flush
Old Oct 26, 2020 | 09:23 PM
Sasnuke's Avatar
Sasnuke
If you want to stick with a staggered 18 setup, then here's some ideal specs. The challenge would be finding rims you like with the exact specs.
Tire size could impact the rim specs slightly.
I would recommend:
18x8.5 +28 (finding this in the real world is likely unlikely...+30 would be good...or +35 and you could use a drop-in 5mm spacer)
18x9.5 +38 (this is pretty much as good as it gets)
Old Nov 2, 2020 | 09:15 AM
aljf69's Avatar
aljf69
on the 18 wheel size set up , what spec provides the widest stance without spacers for example if i choose 18 x 8 all round or 8 1/2 if ok on front , how much offset gives max width stance
Old Nov 2, 2020 | 09:18 AM
Sasnuke's Avatar
Sasnuke
So far the widest square setup has been 18x9.5 +38.
stlgrym3
Apr 5, 2017 10:33 AM
geero
IS F (2008-2014)
Jun 7, 2016 12:34 PM
tures
Jun 2, 2013 03:47 PM
Rykster
Apr 26, 2011 10:05 PM
gunit76
Feb 13, 2010 03:06 PM
