New brake discs and brake pads pulsating when braking at highway speeds
Like others have said, get them to check those rear calipers. They need to show you that they are sliding properly.
I guess I should add that IF the rear calipers are sliding properly then it may be a collapsed hose or sticking caliper
piston that is causing the issue.
Hi new to the clublexus forums and I also have the same problem and had bought brand new drilled and slotted rotor and new pads they were pulsing after 200-300 miles so I had them turned and it fixed the problem for another 200-300 miles...
You are probably not bedding in the pads properly. You need to makes several 60-5mph hard brakes in a row to lay down pad material on the rotors and establish a wear pattern.
New York
Suspension and Brakes
06-02-09 06:59 PM
