Squeaking
Old Apr 1, 2015 | 02:46 PM
JDFelder's Avatar
JDFelder
Default Squeaking
My brakes squeak when I first drive the car in the morning and also when the car has sat for over an hour. They only squeak the first couple times I use them at slow speeds and after that they are quiet. The rotors have been spun and my pads are relatively new. They also squeak a bit more in the rain which I assume is normal. Help!
Old Apr 1, 2015 | 06:29 PM
getafewliv's Avatar
getafewliv
search for the brake shim kit. Lots of threads on the subject. Mine squealed right before stopping, shim kit fixed it 100%. $30 for the set, easy install.
Old Apr 1, 2015 | 10:57 PM
SeanO's Avatar
SeanO
They'll run better/ quieter when they're warmed up/ hot
Kinda like your engine
Old Apr 3, 2015 | 12:51 PM
Gville350's Avatar
Gville350
I bet you park outside where moisture can collect on the rotor surface and creates surface rust. The noise is the minor surface rust coming off via the brake pads. Happens to me every time I wash my car.
Old Apr 9, 2015 | 08:24 PM
dnwin's Avatar
dnwin
Whats this brake shim kit I have been hearing about??
What kind of brake pads are people buying for less brake dust and no squeak??
Old Apr 10, 2015 | 11:52 PM
Nixcision's Avatar
Nixcision
I get a squeak / screech whenever I'm in reverse, backing out of a parking spot or driveway from the brakes... I'm assuming gravel is the issue?
tripperlex
Suspension and Brakes
Jun 21, 2013 06:18 PM
wjimmy
Oct 6, 2008 02:46 PM
blk250
May 1, 2008 02:22 PM
MrLex22
Aug 1, 2007 09:30 AM
kreativ
Maintenance
12
Apr 13, 2005 06:26 PM
