The famous rear suspension squeak
HELLO EVERYONE IM SURE MANY OF YOU HERE EITHER HAVE OR HAVE HAD THIS PROBLEM,
THE REAR SQUEAK SUSPENSION..........
IT IS KNOWN TO BE THE (REAR CARRIER BUSHING)
CAN ANYONE TELL ME THIF THIS IS IT?
That appears to be for the radius arm which FIGS sells and they are poly.
What I'm thinking you are in need of however this. If you are referring to the control arm:
one is for the knuckle, the other is for the other end of the control arm
Have the same problem on the rear, every mechanic I've taken it too has said it would either be the control arm, or the struts none however have been able to actually fix the issue. Overall ride quality is fine however it's just the squeaking that is driving me mad. For those of you that have had the part listed here installed, has it stopped the squeaking?
I had a squeaking noise when driving slow, usually in parking lots, neighborhoods and leaving my driveway. At high speed i was unable to hear the noise. My mechanic determined it was the one of the rear knuckle. With both rear tire up, he was able to slightly lift one of the entire rear tire upward about 1 inch. The other side was solid. The part was about $35 bucks from Ebay and it was from UK. Had to be pressed out. Hope that helps.
http://www.ebay.com/itm/LEXUS-GS300-GS400-GS430-97-05-REAR-ARM-WHEEL-HU-CARRIER-STUB-KNUCKLE-ROSE-BUSH-/171302378966?hash=item27e26addd6&vxp=mtr
I have the same problem! Its actually very embarrasing. If i'm going to change the knuckle is there anyting else anyone would recommend to change as well while i'm down there? My 98 GS400 is already lowered on kyb/megan spring
