spacer is350
I'm looking for spacers for my is350 and not sure how much mm needed to get a flush look, i got the original mag and tire set, anyone have an idea!? will i need extended lug studs? dunno anything about that ! help will be appreciated
thx!
thx!
Not sure on what width spacers you might need on your stock wheels, but when running spacers I do recommend get extended IS300 wheel studs. Problem you run into now is with the extended studs, will the OEM lug nuts work? Some math could probably answer that though; here's something to get you started :
ARP extended IS300 studs are 66mm long
OEM wheels studs are 40mm long
well after reading i found that 15 in front and 10 in rear look almost as flush but hub centric is recommanded right?! do you think this should be good?
Uploaded with ImageShack.us
ok great and this was the wheels ur were running just to be sure (well mine are paint black but it's the same as the gray)!?
Chew on this for a few minutes :
https://www.clublexus.com/forums/is-...2-spacers.html
https://www.clublexus.com/forums/is-...lugs-nuts.html
