no heat?
Old Aug 4, 2012 | 11:01 PM
89supra884's Avatar
89supra884
Default no heat?
i recently tried my heat and found that its not working. the coolant is full and the vehicle has a mishimoto radiator. the car does not overheat at all, and when i do turn the heat on its has kind of a musty smell to it. the heater core is not leaking because it is not wet on the carpet. is it maybe just clogged or has anyone else had this problem.
thankyou
Old Aug 5, 2012 | 02:06 AM
soarer13oy's Avatar
soarer13oy
Check to see if the vacuum line on the heater control valve is hooked up. If it is check to see if the connector is plugged in.
Old Aug 5, 2012 | 05:52 AM
ihiryu's Avatar
ihiryu
SC300 or 400?
If it's a 400 then make sure you add coolant to the upper coolant neck via 17mm bolt. If you just filled through the radiator then it's not bled
Old Aug 5, 2012 | 12:22 PM
89supra884's Avatar
89supra884
its a 300. ill deffiently check that vacuum line out as soon as i get a chance.
thankyou
Old Aug 6, 2012 | 08:28 AM
TweakTech's Avatar
TweakTech
If you can, have someone sit in your car and switch your CC **** from hot to cold and back to hot again. Look at the actuator on the heater valve on the firewall and see if it moves.
Old Aug 7, 2012 | 08:52 AM
6N1SC's Avatar
6N1SC
Like others said, check the heater control valve. If you need to replace it, there is a good DIY here detailing about a replacement heater control valve that costs MUCH less than the $300 something lexus part.
Old Aug 18, 2012 | 09:32 PM
89supra884's Avatar
89supra884
it ended up being just the vacuum line! thanks for all the help!!
Session101
Dec 6, 2013 02:48 PM
msc300
Jan 26, 2012 05:38 AM
sc3dreamz
Jan 24, 2008 02:02 PM
LGR95SC300
Dec 31, 2007 04:04 PM
