Rear break options (LS400 front)
Old 08-08-12, 08:49 AM
gs400rpg
gs400rpg's Avatar
Default Rear break options (LS400 front)
I know alot of people upgrade the front GS brakes to the LS400 ones. But what upgrades are done for the rear?
Old 08-08-12, 11:29 AM
sakataj
sakataj's Avatar
the word is brakes and most of us including myself just upgrade rotors/pads/lines on the rear (i have a actual front BBK and my rear with upgraded pads/rotors/lines is more than adequate, although for aesthetics i am planning to do a matching rear BBK)
Old 08-09-12, 05:28 AM
gs400rpg
gs400rpg's Avatar
My english may not be perfect sorry, I am from quebec after all...
So the only other choice was bbk? I figured the LS might have had 4 pistons in the back aswell. Since mine are jammed up I figured replacing them with something better could be an option then buying new or used GS ones.
Old 08-09-12, 06:34 AM
sakataj
sakataj's Avatar
even in canada the word is still brakes.....
as far as i remember the GS uses a 2 piston rear and so does the LS/Supra/SC (this may not be 100% accurate but this is what i recall) buy some used rear calipers, upgrade your rotors, pads,lines, fluid and you should be good to go........my suggestion is to upgrade the front with the rear so braking isnt biased F/R
Old 08-09-12, 08:12 AM
bachde
bachde's Avatar
For dual pistons...
I believe the supra tt rear caliper look alot better than GS400 rear.
But the LS400 4 pistons look much better than the supra tt... lighter too...
Or the LS430 rear caliper look nice too
De
Old 08-09-12, 08:25 AM
sakataj
sakataj's Avatar
Originally Posted by bachde
For dual pistons...
De
see now your confusing things....you mention both front/rear brakes
while aesthetics aside, the supra rear (from memory) doesnt fit the GS and isnt worth the trouble to make it fit (making a bracket). i almost wanna say (again from memory) the Supra is a smaller rear design that the GS
the LS400 rears are NOT 4 piston although the fronts are
LS430 think you need a bracket made to mount the LS430's also
Old 08-09-12, 09:41 AM
bachde
bachde's Avatar
thanks man
I didn't know that... but aesthetics is what I'm talking about.
So to upgrade GS rear only after market BBK....
Unless stick with OEM.
thanks again
Old 08-09-12, 10:55 AM
2GSC300
2GSC300's Avatar
Actually, TRD has a 4 piston rear option for our car
Old 08-09-12, 11:27 AM
repugnante
repugnante's Avatar
It comes down to what you want to spend. If you got the dough, go with the LS400 upgrade like most on here have done (I may do this as well) OR if you're strapped for funds, just uprgade the lines and grab some Akebono's. Repalce rotors if warped, but again, it's all about your cashflow
Old 08-09-12, 11:53 AM
sakataj
sakataj's Avatar
link?
he's talking about the rears NOT the fronts
Old 08-09-12, 02:04 PM
repugnante
repugnante's Avatar
Yea, Brian I was kinda referring to the rear in my last sentence. But if he has the funds, he can upgrade the rear rotors with lines
Old 08-10-12, 06:50 AM
gs400rpg
gs400rpg's Avatar
In quebec we say "freins". It's a spelling mistake on my part, get over it
I will look into getting some OEM used then.
The rotors that were on the car are slotted but seem very loud. I had in mind to change to some regular ones to correct this
Old 08-14-12, 10:05 AM
2GSC300
2GSC300's Avatar
link?
Here is a link to the pic:
http://www.upgarage.com/upgarage/gaz...53004202s0.jpg
Old 08-14-12, 11:13 AM
akitomk3
akitomk3's Avatar
lol that looks like supra front bbk
Old 08-15-12, 11:11 AM
sakataj
sakataj's Avatar
i was over it when you mispelled it the first time
um, the fronts (red ones) are TRD'S which was just a rebadged supra front brake kit but those rears arent TRD's nor are they 4 pot, they are 2
they are, back in the day TRD rebadged them and sold them as a "BBK" with their name on it
Quick Reply: Rear break options (LS400 front)
