Rear caliper upgrade besides TT
Old 07-05-12, 04:00 PM
phrozen
phrozen's Avatar
Default Rear caliper upgrade besides TT
ive searched around and havent seen much besides TT, ive seen somenoe thats done is300 rear caliper swap but cannot find the post anywhere, was also wondering if anyone had an idea on ls430 rear caliper swap, any help would be appreciated.
Old 10-21-12, 08:17 PM
topdog849
topdog849's Avatar
sc400 rear caliper is a little bigger then the 300
Old 10-21-12, 08:20 PM
sc400ka
sc400ka's Avatar
sc 400 are a bit bigger and top dog said. however i think a lot of of people say you can us the LS model brakes for your car as well.
Old 10-21-12, 08:23 PM
xspsi6
xspsi6's Avatar
Yea sc400 caliper and rotor has more meat, Simple cheap upgrade.
Old 11-02-12, 12:58 AM
FrictionSc
FrictionSc's Avatar
What is needed for this upgrade?
Old 11-02-12, 10:08 AM
Clean400
Clean400's Avatar
While we're on the subject. What's better LS400 95+ Rear brakes vs SC400 rear brakes? Also I know Supra TT Rear Brakes are the best upgrade for SC400. Are the N/A Supra brakes an upgrade for the SC400 rears?
Old 11-02-12, 10:11 AM
topdog849
topdog849's Avatar
I don't think the ls400 rear calipers fit the sc. just the fronts. I believe the supra n/a and sc300 have the same brakes so the sc400 would be better then supra n/a due to the added weight of the v8
Old 11-02-12, 02:10 PM
OG Dada
OG Dada's Avatar
https://www.clublexus.com/forums/sus...00-brakes.html
Old 11-02-12, 07:10 PM
xspsi6
xspsi6's Avatar
The v-8 is actually lighter than the 2jz and the sc400 and supra share the same rear brakes just to clarify
Old 11-02-12, 09:19 PM
Candela
Candela's Avatar
Pretty sure the SC400 is still heavier for unclarified reasons
Old 11-02-12, 09:58 PM
xspsi6
xspsi6's Avatar
Nope you have an all aluminum v8 vs a cast iron straight six, The 1uzfe is actually lighter than most cast 4 cyl engines.
Old 11-03-12, 07:27 PM
Candela
Candela's Avatar
I know the 2jz is heavier than the 1uz, but I'm talking about an overall curb weight difference between an sc300 and an sc400.
Old 11-03-12, 08:27 PM
xspsi6
xspsi6's Avatar
Why would the 400 weigh more than the 300 ?
Old 11-03-12, 09:20 PM
Clean400
Clean400's Avatar
SC300
Curb weight ranges from 3494 lbs. in 1992 to 3560 lbs. in 2000.
SC400
Curb weight ranges from 3575 lbs. in 1992 to 3655 lbs. in 2000.
With a manual transmission swap I'm sure the SC400 is lighter.
Old 11-03-12, 10:33 PM
xspsi6
xspsi6's Avatar
I hardly think 80 # warrants a bigger rear brake set up lol
Quick Reply: Rear caliper upgrade besides TT
