View Poll Results: Please vote - have you had to bring your car in for anything other than regular svc??
No, never had ANY PROBLEMS
62
57.94%
Yes, just once (could have been multiple fixes at the same time)
28
26.17%
Yes, had problems more than once, and have brought it back to the dealer multiple times
17
15.89%
Voters: 107. You may not vote on this poll
2001 and up GS owners.....any problems with your cars??
Old Jan 26, 2003 | 02:51 AM
  #31
Vlad_Stein's Avatar
Vlad_Stein
Let's see...
1) Passenger-side grab-handle on the inside was falling off - replacement.
2) Moonroof cover opens ~1/2 inch and rattles - ongoing problem (stiffer suspension doesn't help, obviously).
3) Glovebox rattle - dealer fixed (more or less) with some felt.
4) Front sway bar bolts came loose during a "spirited" drive through a curvy mountain road - dealer re-tighten and put some lock tite on the bolts. I later replaced the bars and re-tightened anyway.
5) Squeaking/rattling noise from the plastic cover for the ignition module - amazingly went away (reportedly, by itself) after I complained and reproduced a problem at the dealer!!!
6) Driver's seat (back) squeaks when turning the car to the right - must be all the right-turn cornering that I do... Will point it out during my next maintenance visit.
Old Feb 26, 2003 | 01:22 PM
  #32
kvoman's Avatar
kvoman
No problems at all. Bought it from a private party, almost a year now. Just gas it up and go, just as the way it should be. Got new tires (BFG g-Force KDWS) to replace the stock Bridgestone, that's it.
Old Feb 27, 2003 | 11:35 AM
  #33
tod071's Avatar
tod071
Default No problems
2002 GS300 Sport Edition:
I've had this car for just about a year now with no problems whatsoever. Hopefully, knock on wood, this lasts for a long, long time.
Old Feb 28, 2003 | 01:45 PM
  #34
kyle3481's Avatar
kyle3481
i have 01 GS430
no problem at all
now i have 40000 miles on it..
Old Mar 1, 2003 | 10:20 PM
  #35
cdn2k1gs3's Avatar
cdn2k1gs3
Have a 2001 GS300 - Canadian vehicle.
Purchased on March 2001. To date have put 33,000 kilometers.
To date...absolutely ZERO problems.
Old Mar 7, 2003 | 12:20 AM
  #36
BrowserBoy's Avatar
BrowserBoy
Have a 2001 with 45K miles. The TRD sways loosen on occasion, but I always have the dealer tighten those when I get service. I have no rattles or other problems. Nothing... Perfect car.
Old Oct 10, 2003 | 10:34 PM
  #37
jimxo's Avatar
jimxo
Yes, every month I spend about $598.96 on it but the dealer said that will stop when I make the last payment
Old Oct 10, 2003 | 11:48 PM
  #38
LexFather
Guest
Posts: n/a
VVTi and jimxo's responses cracked me up
Old Oct 11, 2003 | 07:26 AM
  #39
chaskim's Avatar
chaskim
Default 2001 GS 300
Had my car for 3 years,
Didn't have the sway bar problem because I replaced the stock ones with TRD less than 5000 miles.
I did have to take the car in as the driver rear side shock was leaking, discovered it when I was replaceing the sway bars.
My tags are due and are more then the car payment, but I live in cali so do something Arnold.
Just had the dealer replace my battery, I don't drive the car all the time.
Sunroof no problem but its open every time I'm driving.
MAJOR PROBLEM: Let my wife drive it because I needed her RX to move some stuff and now I can't get her out of it.
Most of my problems with the GS are like VVTI's but they are not covered under factory warranty
Because its a 300 and not a 430 it seems to be missing some horsepower
chaskim
Old Oct 16, 2003 | 02:09 AM
  #40
charmaine's Avatar
charmaine
so
dose that means below 01 gs was built better than 01 and up??
Old Dec 3, 2003 | 09:56 AM
  #41
jdmaristo's Avatar
jdmaristo
2001 lexus gs300 had it for almost 2.5 years , only probs battery went out,door speaker wires came loose fixed dat, had rattle problem from under the hood checked everywhere couldnt findt it..
Old Dec 3, 2003 | 10:18 AM
  #42
PHML's Avatar
PHML
Master Thread Closer!!
Oh....i forgot.
I had a problem with the driver seat. When I took turns or when getting in and out of the car....it made a thumping sound.....something was loose. I took it apart and found a little nut behind the seat adjustment buttons popped out.
It was a SOB to take apart....but I finally got tightened.
Pete
Old Feb 1, 2004 | 11:40 AM
  #43
Cadd's Avatar
Cadd
Originally posted by charmaine
so
Any opinions on this??? How about those of you who has both the 99-00 GS400 AND THE 01+ GS430? Care to comment?
Thx.
Old Feb 2, 2004 | 10:25 AM
  #44
chicagoblknazn's Avatar
chicagoblknazn
All these sway bar issues are scaring me
Old Feb 2, 2004 | 03:31 PM
  #45
GSpeed's Avatar
GSpeed
Annoying wheel vibration at around 60-65 mph. It does not happen when going slower or faster. I've seen some previous posts that this may be a common problem. Especially on 98-2000 models. Other than that no probs
