Need some help on lowering spring install
I'm currently installing lowering springs. I did the fronts and something seems off about it. The springs are suppose to drop the front 1.6 inches. The front driver side wheels seems really tucked in now and the front passenger side is angled as if I got some camber. Now I'm doing the rear springs and the bolt that connects the shock to the LCA can't come loose even with an impact wrench. I tried jacking up the LCA and removing the nut but still doesn't come loose.
I'm suprised nobody has offered any input yet. Have you looked at the fsport springs install instructions on se well instructions. I've had to do this 3 times now and makes it so easy to follow along. Then again I did remove my suspension with only a couple thousand miles on my two cars. But it was really easy when you do it by numbers according to the instructions. Remember to note the vsc sensor position on the left rear suspension when you disassemble and reassemble the assembly.
chi123
Suspension and Brakes
Dec 18, 2011 09:21 AM
Rickster31
12
Jul 21, 2007 09:55 PM
