Are there any good write ups on LS400 brake swap?
#32
way old revival but why not.
can anyone give a definitive answer on how much spacing is needed on the rca to clear the caliper with no grinding? i have the figs kit on at 17mm, will this be enough to not need to grind? hoping to find out asap so i can get prepped for paint.
thanks guys.
thanks guys.
#33
Probably 17mm based on this guide from FIGs:
http://www.shopfigs.com/v3/LS400RETROkit-17MMISV2
http://my.is/forums/f221/diy-ls400-c...nstall-424586/
jeffy (03-17-18)
#34
thanks for that info. it still adds a bit of confusion, probably due to the is300 focus of it. they are talking about additional inserts for the calipers for the IS and JZX chassis, i havent seen or heard of anyone with a 2GS needing/using these. im assuming the caliper bolts on the IS are smaller, hence the need for an insert to allow that to work? As far as vertical clearance goes it does look like 17mm will work. Lets hope so, ill be kinda bummed to knock some fresh paint off my calipers for clearance at the last minute.
#35
jeffy (03-17-18)
firelizard (06-29-18)
#37
very straight forward install, and yes the 17mm figs rca is just what you need to clear without any issues, only extra is the trimming of the dust shield. and lucky me my wheels cleared without the need for a spacer.
#41
Its not so much about offset as it is spoke design of the wheels. Read this thread
https://www.clublexus.com/forums/sus...400-bbk-2.html
vietnamese
16
11-27-05 05:14 PM
