what if I cut F-Sport Springs .5" front only?
Like most have said, you should never cut your springs unless its your LAST option. Why would you want to cut something that you paid lots of $$$ for, it wouldn't make much sense to me. Ever consider coilovers? Then you can adjust to whatever height you desire.
Had experience cutting springs on a friends Honda, that was a bad idea. Worst ride ever!
Hi all experts...?
Currently I am running with F-Sprt springs, the rear look very nice, but I the front still have a little bit gap.
I am thinking about cutting the front coils a little to match with the rear.
What are your thought on this...?
Don't tell me to get coilovers...I am saving $$$ to buy coilovers..
Thanks.
Thanks.
Cutting your springs will be 10 times worse than that.
cut springs = fail.
sorry to say, but your lack of foresight (you should've gotten s-techs for an even lower ride height) is leading you to a lack of thought (chopping f-sport springs).
strike the thought of chopping your f-sport springs from your memory and do what you should've done in the first place: go w/ s-techs.
You guys should look into having some billet 6061 inserts made to fit between the front lower ball joints and knuckles. I had mine done this way. It took 10 minutes to install and they are 100% reversible.
