Factory Suspension Problem
Old Jun 27, 2008 | 06:24 PM
s6 4rings's Avatar
s6 4rings
Default Factory Suspension Problem
I have noticed lately that the WHOLE left side is leaning. I took measurements, and sure enough the right side of the car is higher than the left. What can do this? I'm a 200lb guy, and the car has 19,000 miles on it.
Can a few of you with stock non sport suspensions with miles check the ride height left vs. right side please and report back. This bothers me.
Old Jun 27, 2008 | 06:29 PM
passnu2's Avatar
passnu2
well I seem to have this along with one other member sincityIS. There was a thread going about this and I will see if I can find it for you....
Old Jun 27, 2008 | 06:36 PM
passnu2's Avatar
passnu2
here is that thread for you....
https://www.clublexus.com/forums/sho...d.php?t=356899
Old Jun 27, 2008 | 06:44 PM
s6 4rings's Avatar
s6 4rings
I saw the thread, which made me ask more now.
Old Jun 27, 2008 | 06:50 PM
s6 4rings's Avatar
s6 4rings
Whats the diff between the Tein CS and SS?? I see a $500 price diff.
Old Jun 27, 2008 | 07:22 PM
sincityIS's Avatar
sincityIS
SS can go lower, CS ride a little smoother due to softer springs.
My car is off 1/4 inch. I have been considering removing the bottom spring cushing to lessen the preload. I think this would probaly level it out, but I am concerned with noise if I do this. I know of some suspensions the ride metal to metal and there is no noise, but I am sure that is how they are desinged. I have not heard anyone have any kind of fix for this. I am going to take it to the dealership again and see if they can fix it when I get some time.
Old Jun 27, 2008 | 07:24 PM
s6 4rings's Avatar
s6 4rings
me too, but coilovers are looking enticing. I have a Audi i wanna sell to get the mod money.
Old Jun 30, 2008 | 07:30 AM
ISF_GG's Avatar
ISF_GG
Originally Posted by s6 4rings
can a few of you with stock non sport suspensions with miles check the ride height left vs. right side please and report back. This bothers me.
I've measured mine, and I'm higher by about 0.5" on the passenger side. I'm about to take care of this issue once and for all with Tein CS coilovers.
Old Jun 30, 2008 | 07:44 AM
nabbun's Avatar
nabbun
you guys without awd are lucky
Old Jul 13, 2008 | 09:42 PM
I8ABMR's Avatar
I8ABMR
this will happen with stock springs or with aftermarket springs. Its caused by the chronic asymmetry in the weight distribution of the vehicle created by the weight of the driver . I am at a cross roads. I have a set of tein h techs on my car that I can swap of tein cs coilovers or just have a local shop swap the springs righ to left. If you have the springs swapped you will get the perfectly even ride height . What I am hearing now is that coilovers need to be rebuilt every 40-50k miles. Stock parts will absolutely last longer than that even with an aftermarket spring. Youre stuck between a rock and a hard place
Old Jul 15, 2008 | 09:38 PM
ISF_GG's Avatar
ISF_GG
Originally Posted by I8ABMR
Its caused by the chronic asymmetry in the weight distribution of the vehicle created by the weight of the driver.
It isn't caused by the weight of the driver. The IS leans all by itself.
Old Jul 15, 2008 | 09:44 PM
lobuxracer's Avatar
lobuxracer
Tech Resource
Some do. Some don't. Mine is one of the latter.
Old Jul 18, 2008 | 03:48 PM
Navigatn's Avatar
Navigatn
hmmm... i have these shims on my subaru. they are 1/4" and are basically strut spacers that are placed btwn the pillowball and chassis. i bet if there was an application for the IS, you could put a pair on the left side struts and problem solved.
Old Jul 18, 2008 | 06:30 PM
sincityIS's Avatar
sincityIS
Hmm, those would work if you could find a way to get longer studs for the tops of the struts. I don't think there is a 1/4 inch to give with the OEM studs.
duncan351
Suspension and Brakes
25
Aug 14, 2023 03:39 PM
llamaboiz
May 5, 2008 07:59 PM
tmf2004
15
Aug 18, 2005 05:53 PM
