Quick question for anyone with Tein CS and 20s
Old Jan 22, 2006 | 01:09 AM
speedie's Avatar
speedie
Default Quick question for anyone with Tein CS and 20s
Whats up People?!?
Hey I'm wondering if any of you guys are experiencing any major rubbing issues with your Tein CS coilover system with the 20 inch wheels and tires??
Also what size tire, wheel and offset do you have?
And how low are you??
Old Jan 22, 2006 | 01:39 AM
joshoowa's Avatar
joshoowa
+35 offsets all around and about 1.5-2 finger gap no rubbing even at hard left and right turns
Old Jan 22, 2006 | 05:25 AM
GS300Rich's Avatar
GS300Rich
I didnt have any rubbing with my old wheels, but with my iForged there was a bit of rubbing in the front on the plastic liner. So I just shaved it down a bit and now no rubbing. My tire is 245/35/20 Toyo T1-R and I am about barely 1 finger gap in front. Not sure of the offset though
Old Jan 22, 2006 | 11:50 AM
rominl's Avatar
rominl
exclusive matchup
full hard lock left and right, rub front and back of wheel well. when hittind a bad dip, rub top of wheel well. both very common.
8.5 +36 i believe, less than 1/2 finger
Old Jan 22, 2006 | 12:21 PM
joshoowa's Avatar
joshoowa
u know i thought i was rubbing because i was too low at one point in time...
i figured out that i didnt push the mud guard back in its proper place...
Old Jan 22, 2006 | 06:57 PM
TPA_STEVE's Avatar
TPA_STEVE
Default tein cs with fat 19" setup also rubs on dips
my tein cs with fat 19" setup also rubs on dips. I have them set on stiffest setting and I've increased to 1.5-2 fingers and only rub occasionally. I had it at about 1 finger and it looked great but the bouncing on dips was driving me nuts so I raised it some. Should I have purchased the flex for lower without bouncing?
Old Jan 22, 2006 | 08:06 PM
Neo's Avatar
Neo
The One
No. The ride characteristics of the Flex and CS are different. If you like how the CS rides, you will not be happy with going to the Flex just to reduce the rubbing,
My fronts are 20x8.5 +43 with 1-1.5 finger gap. Rubs the top on big dips and one full lock turns. With the full lock turn rubs, I just need to work the fender lip a little more.
Old Jan 22, 2006 | 08:20 PM
916gs300's Avatar
916gs300
I dont have the teins suspension, but I have the espelir spring and running on Iforged 20's, no rubbing at all even with four people in the car. 1finger gap on all for corners.
Old Jan 22, 2006 | 08:31 PM
bluelex's Avatar
bluelex
20x8.5 front +36 no finger gap was rubbing a little in hard dips, rear 20x10+36 no gap no rubbing but everything was rolled away..
RI-Lex
Aug 5, 2009 07:15 PM
tone4
Suspension and Brakes
28
Mar 28, 2008 09:03 AM
biggie
Sep 30, 2006 01:16 AM
YoungP08
12
Oct 29, 2005 09:25 PM
Lexy GS430
Feb 9, 2005 06:04 PM
