GS430 L-Tuned Suspension Install
Subscribe
Jan 22, 2010 | 12:28 PM
  #106
Back from the dead.. me and a friend tackling this today. Hopefully all goes well.
Reply 0
Jan 23, 2010 | 12:13 PM
  #107
finshed mine last week it rides good and looks great i wouldnt want to go any lower
Reply 0
Aug 1, 2010 | 08:07 PM
  #108
Thanks for the writeup. It was very help full this weekend on the GS400. I replaced the struts with some new OEM units. Have to keep it cozy for my wife as it's her daily in the 70 mile a day round trip with our baby to and from work. Also replaced the tie rod ends so it made it a bit easier as I could turn the assembly by hand
Reply 0
Nov 17, 2010 | 10:19 PM
  #109
Nice write up. Your information was very helpful but I ran into a little bit of trouble.
https://www.clublexus.com/forums/sus...t-springs.html
Reply 0
Mar 19, 2011 | 12:34 PM
  #110
Today I discovered that one of my front springs has broken, which may explain the vibration I had assumed was engine mounts. It's at the very bottom, so the car is still drivable, but:
Since the l-tuned shocks and springs are discontinued, what do I replace them with?? I am only going to replace the fronts, and I would just replace the spring if I could be assured it was identical.
Reply 0
Mar 19, 2011 | 12:40 PM
  #111
The Eibach springs are the closest thing to the L-tuned springs.
Reply 0
Apr 2, 2011 | 12:21 PM
  #112
Thank you so very much for this write up!
Just installed an Eibach Pro-Kit for my GS3 and no surprises. Although the front was a major pain in the *** because I changed out the caster arms as well on both sides, and getting the two bolts to go back in drove me insane.
Anyhow, I used the stock bumpstops in the rear but didn't cut them, and hear some noise =( anyone here have the same issue? Don't really feel like taking them back out to cut the stops in half.
Reply 0
Apr 2, 2011 | 05:51 PM
  #113
I just installed Eibach springs in the front as an l-tuned replacement, reused my l-tuned shocks, still have l-tuned s/s in rear.
This guide was EXTREMELY helpful.
The Eibach springs are very close, though not identical.
The spring that broke may have had a material defect; a split was visible in the cross-section of the break.
Edit: Why isn't this thread a sticky? It has more views than any of the other sticky threads in this section. Google 'gs430 suspension install'.
Reply 0
May 25, 2011 | 05:49 AM
  #114
Thanks for this guide and the useful comments. I'll be installing my S-Tech springs and KYB shocks soon.
Reply 0
Jul 9, 2011 | 06:31 PM
  #115
This is some very helpful info,I will be looking at this thread when I'm ready to drop....
Reply 0
Aug 17, 2012 | 12:01 PM
  #116
Guide helped a lot. The rear is harder than front...it's just a lot of wrench turning and lining things up. I can see how this is $500 in labor. I like to go slow, clean, and lube all chassis points. Strong sockets are a must..any kind of play and you will strip bolt on the big ones.
Reply 0
Jan 8, 2013 | 10:09 PM
  #117
This is a very helpful write up. thanks for putting this together. Worth its weight in gold
Reply 0
Feb 22, 2013 | 10:14 AM
  #118
I'm tackling this this weekend!!! Back from the dead. Any other tips or tricks from others? Can I use that puller to replace the lower ball joints while I'm down there? Can't I simply put that on one end of the lower control arm and the other on the ball joint and use a ratchet to push the ball joint out? And the cars weight to press it back in place??
Reply 0
Dec 20, 2013 | 06:42 PM
  #119
About to try to replace my shocks. How do I get to the top of the rear shocks, do I need to remove the back seats?
Reply 0
Aug 29, 2014 | 02:27 PM
  #120
Revive. DF210s just came in today. This has to be one of the greatest DIY threads ever.
Reply 0
