2016 AWD Base Coilover Questions
Old Apr 3, 2023 | 09:46 AM
TomB517's Avatar
TomB517
3rd Gear
Default 2016 AWD Base Coilover Questions
Hi everyone, I have some questions about coilovers for my IS300. Its AWD, and I've decided to go with the BC Racing BR-Series. As this is my first ever set of coilovers, my question is, do I need additional suspension parts to get the suspension back within spec? I only plan to drop it a little bit to get rid of the wheel gap. Also, is this something an inexperienced person could install themselves? I can do an oil change and have the tools, but I've never done suspension work myself. I also have a set of RCF LCA bushings on the way if that matters? Thanks for helping out a noob!
Old Apr 3, 2023 | 03:07 PM
laobo979's Avatar
laobo979
Welcome suspension work nothing like oil change haha. Depending if you bolt are rusted in or not will determine if you need more tool/parts. Stuff like your end links. You’ll likely need an alinement most importantly get front and rear toe to zero to save your tires.
Oscar8710
Suspension and Brakes
Mar 22, 2022 08:51 AM
Br4den
Jul 14, 2021 09:19 AM
truu
Jan 28, 2019 10:41 AM
rickpalace
May 13, 2017 09:05 AM
Breakergx
Suspension
Oct 4, 2010 01:13 PM
