Site Suggestions & Problems Bring up any suggestions, questions or problems concerning ClubLexus. If you need to test a forum feature, post here too. Note - questions about your Lexus do not belong in this forum!
thread moved
Old Feb 3, 2005 | 09:26 AM
mhill's Avatar
mhill
Default thread moved
When it says thread moved, where is it moved to? How do you find out?
Why are certain threads moved? They seem to be on subject and posted in the correct
area???
Old Feb 3, 2005 | 09:36 AM
DaveGS4's Avatar
DaveGS4
Administrator Emeritus
area???
If you click on the little marker that says 'thread moved' (which is called a redirect) it will take you right to the new thread in the forum where the thread was moved to. We can move threads without redirect as well, but don't ususally do that.
Threads are moved mostly because they've been put in the wrong place. For example, you might have posted something about a 2005 LS430 in the LS400 forum - now that we have a specific LS430 forum the thread should be moved there. Or there could be a post about detailing your LS that belongs in the detailing forum instead of the LS forum where we have a dedicated professional detailer as our moderator. Or someone posted something for sale or a want-to-buy post in the main forums instead of the classifieds, etc etc etc.
The moderators have a pretty good handle on where things belong and move them for a reason, not just because they like moving threads.
If for some reason you can't locate a thread you posted, either because it was moved or you simply can't remember, you can always just click on your username in any post to get to your profile
https://www.clublexus.com/forums/members/32022-mhill.html
and then select find all posts by mhill or find all posts selected by mhill
Alternatively, you can use advanced search and put your name in the username field to search for your posts.
Hope this helps
07-IS350
Dec 13, 2009 10:55 AM
dseag2
Dec 1, 2003 12:50 PM
