IS350 A760E Transmission Value body upgrade (Shift kit)
Hi guys
Has anyone tried this Transgo Shift kit https://www.ebay.com/itm/Transgo-SK-...-/272642949400
I have seen a lot of people wanting to upgrade 2IS transmission shifting response. Maybe this is the fix?
It seems to be available for quite awhile but I haven't seen anyone talking about it ( Or I didn't look hard enough? ).
Any review? More info is appreciated
Thanks!
Thanks!
I'm 99.8% convinced the trans shifts exactly when the solenoids are instructed to via engine ecu and trans tcu. That you will not be be correcting the lag from paddle/shift lever changes when manually shifting. That deficit is a product of the ECUs programming not anything to do with the valve body function.
So unless running boost or you have some other problem with the trans behavior, doing things like increasing the line pressure or stuff like that is simply a quicker means to an end through increased heat and wear from higher pressures.
JM2C
JM2C
Thannp
03-17-21 03:22 PM
hydromatic
RX - 1st Gen (1999-2003)
07-01-19 05:19 PM
