ES - 7th Gen (2019-present) Discussion topics related to 2019+ ES models
mudf guards on the 2019
Old 04-20-19, 11:30 AM
bc6152
bc6152's Avatar
Received 1,238 Likes on 870 Posts
Default mudf guards on the 2019
Finally got the chance and the weather to install mud guards on my new 2019 UL 350. I only did the fronts as the boss has me peeling potatoes for the Easter dinner tomorrow.
I was able to utilize the existing factory fasteners, one was a push clip and the other a hex head screw. FYI - the Lexus clip is very easy to get out with a clip removal tool - about
$3.00 on Ebay. Without the tool one can use a flat head screwdriver to slip it under the clip head, pop it out carefully, then remove the bottom part. They can then be reused.
For the rear guards to be installed the wheels will have to be removed.
Here are a couple of photos:
The following 2 users liked this post by bc6152:
AnthonyMJ (04-20-19), MSterling (04-21-19)
Old 04-21-19, 01:25 PM
MSterling
MSterling's Avatar
Thanks for your posting. I have been waiting to see how this was done, before ordering the parts. I am concerned about removing the rear wheels, which I really don't want to manage. I was hoping that I could use the clips and possible screws with a ratchet wrench to maneuver inside the wheel well.
Old 04-21-19, 01:35 PM
bc6152
bc6152's Avatar
The clips are not the issue but the screw might be. BTW - the screw on the front is not a hex it is a TORX... I have a 90 degree ratchet screwdriver that I might be able to use on the rear.
If possible I would like to also avoid removal of the wheel. Raining here today and family over so no mud guard work today... I'll post when I do it... The fronts took me no more than 30 minutes...
Old 04-21-19, 01:40 PM
MSterling
MSterling's Avatar
I may or may not have a Torx head. What size would I need? For the price of doing this myself, I might just go buy it.
Old 04-21-19, 01:51 PM
bc6152
bc6152's Avatar
It's a 25...
Old 04-21-19, 05:45 PM
mikemu30
mikemu30's Avatar
Received 2,353 Likes on 1,694 Posts
Mud guards look good. How did the potatoes come out though?
Old 04-21-19, 05:55 PM
bc6152
bc6152's Avatar
HA! She made potato salad. mmmm good... wise guy...LOL
Old 04-23-19, 09:09 AM
ES63
ES63's Avatar
where did you purchase the mudguards ?
Old 04-23-19, 12:38 PM
bc6152
bc6152's Avatar
https://www.ebay.com/itm/XUKEY-Molde...wAAOSwAQVb7Nqs
ES63 (04-24-19)
Old 04-30-19, 02:23 PM
bc6152
bc6152's Avatar
We had a beautiful day here in Southampton so I tried installing the rear mud guards since the fronts are on. The good news is that there is no need to drill any holes anywhere back there. There is a factory clip at the top which just pops out with a clip remover or a thin flat blade screwdriver. Pop the head off the clip and the base slides right out. At the bottom is a factory plastic grommet that accepts the galvanized screw that comes with the mud guards. Both holes in the mud guard line up with both holes in the rear wheel well shield.
The bad news is that the rear wheel must be removed. Not easy on your driveway... I jacked up the rear of the car and removed the tire to get at the lower screw. No way to get it fastened w/o the wheel being removed... These wheels and tires must weigh 100 pounds. Anyway, the install was a success, the guards look great, and no modification to the car was necessary.
The hardest part was getting the wheel BACK ON the lug nuts.
AnthonyMJ (04-30-19), MSterling (04-30-19)
Old 04-30-19, 02:29 PM
MSterling
MSterling's Avatar
@bc6152 thanks for the great pics and the insight.
Old 04-30-19, 02:30 PM
AnthonyMJ
AnthonyMJ's Avatar
Thanks for the update. Looks nice.
BoostAddct
07-15-14 12:00 PM
kblair3d
04-24-14 07:05 AM
vdeyfi
05-11-12 03:44 PM
ontoy
03-06-10 03:43 PM
BLexACK LS
Maintenance
07-14-03 07:04 PM
Quick Reply: mudf guards on the 2019
