Side Mirror lighting..LED?
I want to replace the bulbs in my mirrors, 09 ES replce them with LEDS. . I use superbrightleds.com for my bulbs and they have the trunk, and door lights, but do not have the mirror light. Anybody know what number bulb the mirror light is? Thanks in advance.
T10 bulb.
I changed those to LED and they look fine. Be careful with the mirror glass.
Any chance you remember where you got the bulbs the T10s superbrightleds have are $15 a piece... Want to see if theres any other options before buying these.
I can’t find the exact same type but I know they have to be short and flat because there’s no space for bigger ones.
They should be similar to those:
Look what I found on AliExpress
https://www.aliexpress.com/item/3268...681621956.html
I think these are the best:
8 Pcs - OPT7 Advanced Bright LEDs - T10/194/168 - 180 Flat 4-SMD White Light
Conor09ES (01-27-18)
8 Pcs - OPT7 Advanced Bright LEDs - T10/194/168 - 180 Flat 4-SMD White Light https://www.amazon.com/dp/B00KFPE03S..._hElBAbGARCK6X
*EDIT.. i just found this quote from someone on this forum, is it correct?
Tilt the mirror towards the inside of the car and up
reach for the bottom outside(away from the car) corner and wedge your fingers in that gap
apply some nice steady pressure until you pop out the bottom taps..
push up to unhinge the top hooks
do not worry about the white gooey stuff... and jsut let the mirror dangle.
you'll have 4 philips head screws i think.. unscrew them
wiggle the housing apart and there you have it.
*EDIT!! I tried the above method very carefully, and I somehow managed to crack my mirror glass..
I cracked mine too, 3 years ago.
It’s around $250.
It’s around $250.
OEM comes with dimming and heating functions.
Conor09ES (02-02-18)
Majek
03-27-15 08:14 AM
