brakes pulsating
Old 09-18-17, 05:19 PM
murphcc1
murphcc1's Avatar
Default brakes pulsating
Alignment checked, NEW rotors and pads(did it with the old rotors and pads with only about 7k miles on them).........and I STILL have the pulsating in the pedal....I can even feel the pulse at slow speed in the pedal...not so much in the steering wheel.
Any thoughts?
Old 09-18-17, 06:35 PM
salimshah
salimshah's Avatar
Seems like re-surfacing (turning of) rotor is needed. Which one? Can be any or all 4 wheels.
Machinist have a dial gauge and they can measure and tell which rotor or all are bad. [Machinist should know to compensate for run-out --- wobble in the bearing]
Salim
Old 09-19-17, 04:52 AM
Drcoffee
Drcoffee's Avatar
Lower Ball joints or tie rods. Or seized, frozen brake caliper.
Old 09-19-17, 05:14 AM
murphcc1
murphcc1's Avatar
Thanks guys......
***** joints are all fine.
TWO set of new front rotors and it did the same thing....so .....pretty sure it's not the rotors.......
Calipers are free to move......
NOW I'm starting to think it might be the ABS kicking in............gonna take them out and clean them on Friday........too much weather heading into the North East next few day.....
Old 09-19-17, 06:04 PM
Drcoffee
Drcoffee's Avatar
Just pull the under hood fuse to the ABS and road test it.
Old 09-20-17, 12:56 AM
artbuc
artbuc's Avatar
Any thoughts?
Rotate tires...could be a balance issue. If it is, pulsation will be noticeably less with bad tire(s) in the rear.
Old 09-20-17, 07:47 AM
sktn77a
sktn77a's Avatar
I had exactly the same on my RX. "Calipers are fine" - but they weren't! When its doing it real bad, jack the car up and try turning the wheels. Could also be a collapsed brake line but that's pretty rare. Have you checked the wheel bearings?
Old 09-20-17, 08:05 AM
2013FSport
2013FSport's Avatar
Received 1,484 Likes on 1,238 Posts
Pothole wheel damage?
At speed a slightly bent wheel can nearly go unnoticed, during braking weight transfer loads the tire and you can feel that flat spot transmitted into the chassis.
Get the wheels checked. They will balance fine but a bent lip does exactly what you're talking about and it doesn't take much deflection to feel this.
Old 09-22-17, 02:45 PM
murphcc1
murphcc1's Avatar
Already rotated tires and had alignment checked at the same time.
Pulled the fuse for the ABS and I don't have that BAD pulsating anymore.
But I do apparently have a warped right rear rotor.......can feel it in the car on braking.
Gonna replace the rear rotors and remove and clean ALL ABS sensors.
Thanks for all the help!!
kings222
IS F (2008-2014)
30
04-19-23 01:00 PM
ishootstuf
Suspension and Brakes
35
02-02-22 03:54 PM
Ken167
04-26-19 04:59 PM
ThumperPup
ES - 5th Gen (2007-2012)
04-17-18 01:26 PM
lex_rx
06-21-11 06:11 AM
Quick Reply: brakes pulsating
