Seafoam on 3rx?
Old 07-09-15, 01:47 PM
jeruhmee
jeruhmee's Avatar
Default Seafoam Rx350?
Im just curious if anyone here has ever seafoam their RX350? If so, where is the vacuum line located?
I have first hand experience with seafoam on camry, intergra, accord, rav4, and tundra. They seemed to idle better and run smoother after.
Old 07-10-15, 05:28 AM
Clutchless
Clutchless's Avatar
Received 1,098 Likes on 937 Posts
I have done it using a vacuum hose connection on the intake manifold just past where the rubber air intake attaches. This was last fall, I need to look again to verify the position. I think if your Camry also had the 3.5 V6 that the hose is in about the same location.
I think there are better products than Seafoam itself with which to perform an induction cleaning service. Redline fuel system treatment used full strength is a stronger cleaner. Also Techron fuel system cleaner or the 3M product line made for this service.
Amazon.com: 3M 39089 Fuel System Tune-Up Kit: Automotive Amazon.com: 3M 39089 Fuel System Tune-Up Kit: Automotive
I use BMW fuel injector cleaner, the blue stuff that has to be diluted with gas. I think Techron makes it for them. I have the drip feeder that looks like an IV so I get a slow feed of cleaner over a 10-15 minute period.
You may want to look at the ToyotaNation - Highlander forums as they have more owners that do their own maintenance.
Old 04-27-17, 12:40 AM
gianttama
gianttama's Avatar
Default Seafoam on 3rx?
As titled, had anyone done it and is it necessary? My 13 450h has just over 50k miles.
Old 04-27-17, 07:29 AM
salimshah
salimshah's Avatar
Is there a problem you are trying to address?
Salim
Old 04-27-17, 09:35 AM
F250
F250's Avatar
Some folks do it proactively on every vehicle they own. Unless you're hitting (or PLANNING on hitting) really high mileages -- >150K or 200K miles, I wouldn't worry about it. It's not like these Toyota engines are known to be sludge buckets like some of their European counterparts.
Old 04-27-17, 10:50 AM
salimshah
salimshah's Avatar
Good regular maintenance and care can get the desired high milage. Additives may or may not help and if not used carefully will end up hurting. I would say avoid unless it can help you solve a problem.
Salim
Old 04-28-17, 03:52 AM
Freds430
Freds430's Avatar
Received 1,059 Likes on 693 Posts
if you are buying a used car and it has been abused might be helpful. If you are using synthetic and change the oil every 10,000 waste of money.
Old 04-28-17, 08:24 PM
gianttama
gianttama's Avatar
Thanks guys, not trying to cure any problem, was just thinking if necessary as preventive maintenance. For the car at 23k miles free years ago now 51k, been using synthetic all the time every 5 k
Old 04-29-17, 11:56 PM
salimshah
salimshah's Avatar
<FYI> There is more than just oil for seafoam treatment. Air intake and fuel injection paths are also involved in the treatment.
Salim
keshwar
ES - 6th Gen (2013-2018)
13
08-28-20 07:43 AM
dtapatia
RX - 4th Gen (2016-2022)
30
06-18-20 07:50 PM
pitmanr200
07-29-08 08:30 AM
Lextranny
05-01-08 11:46 PM
Topshelf
RX - 1st Gen (1999-2003)
08-31-07 11:48 AM
Quick Reply: Seafoam on 3rx?
