Key Fob Range
Old 02-07-17, 01:20 PM
DshngDaryl
DshngDaryl's Avatar
Here is the information we have been looking for. The receiver is in the Rear View Mirror
https://www.clublexus.com/forums/sc4...ansmitter.html
Any chance you have anything hanging off your mirror Shawn that might be blocking the signal?
Old 02-07-17, 01:38 PM
ShawnOk
ShawnOk's Avatar
Nothing handing off the mirror, but thank you for this linked thread! It confirms what Retroplay has told me previously when he altered his mirror LED. He believed that the mirror houses the antenna for the system. So this is something I might try to start troubleshooting. I see two "eyes" on the mirror; one on the front, one on the rear. Anyone know to what system these might be related?
Old 02-07-17, 05:54 PM
Harold57
Harold57's Avatar
Any chance that Retroplay has pictures of the interior of the mirror?
Old 02-07-17, 08:21 PM
ShawnOk
ShawnOk's Avatar
So there are some photos posted in the linked thread, but I can't really identify which is the antenna or even what point/where I'd like to solder an extension wire. Anyone got any ideas? Post 74. https://www.clublexus.com/forums/sc4...led-mod-5.html
Old 02-08-17, 10:35 AM
DshngDaryl
DshngDaryl's Avatar
I do not know. I do not know AT ALL, but I think this looks like an antenna wire. The one the green arrow is pointing too.
Old 02-09-17, 12:59 PM
Harold57
Harold57's Avatar
I was wondering about that also DashingDar. There is a good chance that the SMD pointed out in red is the likely antenna but I'd need a much closer look at it. The gray wire (green arrow) I thought might be one at first but I suspect that could be carrying power to some components in the front assembly, but once again I'd need to have a closer look and see where all that goes. For 418MHz it would be about 18" but for 315MHz it would be closer to 24" if it is a wire type antenna. Both are definitely possibilities though.
Old 02-09-17, 01:07 PM
DshngDaryl
DshngDaryl's Avatar
I think the SMD is just a light. I took the picture off the post on how to change the SMD's color. I could be wrong.
Here is a picture of the circuit board still in the housing. Take a look at the gray wire. It is white in this picture, but it really looks like it could be an antenna wire that runs the length of the mirror for maximum reception
Old 02-09-17, 01:29 PM
Harold57
Harold57's Avatar
I agree. It might be more obvious though if that bottom assembly were removed (or even more so if I had it in my hands). The part number is there, in case anyone has access to the drawings.
Old 05-28-19, 10:22 AM
ryanSC300lover
ryanSC300lover's Avatar
https://www.clublexus.com/forums/is-...try-issue.html
Is yours fixed? I am having same issue
Old 05-28-19, 02:27 PM
ivanj
ivanj's Avatar
This must be contagious. What I've found is that it takes several seconds between an open sequence and a close sequence for the remotes to work.
louczar
RX - 3rd Gen (2010-2015)
14
02-28-19 07:33 AM
JMan23
11-06-18 02:43 PM
ZAM
RC - 1st Gen (2015-present)
20
07-10-15 09:18 PM
theoryguy3
01-15-14 08:54 PM
Quick Reply: Key Fob Range
