Remote Keyless entry issue
Old May 28, 2019 | 09:01 AM
ryanSC300lover's Avatar
ryanSC300lover
Default Remote Keyless entry issue
Whenever the key fob is around the passenger seat, and I go to turn the "ON" button to start the car, the car is not recognizing that there is a key inside the car.
I thought maybe "key battery" was getting old. I put in two new batteries on both of my remotes.
However, I am still have that issue.
Car door locks/unlocks fine, when proximity key is near.
Any solutions?
Thanks
Old May 28, 2019 | 10:21 AM
ryanSC300lover
For lack of a better term, it seems like its a "decreased range" suddenly....
Old May 28, 2019 | 02:43 PM
2013FSport's Avatar
2013FSport
Is this a new problem? Look in your manual, you can select which part of the cockpit is active with Techstream.
That said I have found 2 things that promote that problem. Close proximity to cell phone (remember the worse your cell signal is, this forces it to raise its Tx power out to maintain contact with cell tower). The second item is the 12v USB charger. If the key is close to it, its EMI emissions interfere with fob contact to its antenna friends in the c@ckpit.
That aside you might clean the battery and fob contacts with electrical contact cleaner. Greasy / salty finger prints can oxidize causing a bad connection. Takes about 3 months.
Old May 28, 2019 | 03:07 PM
ryanSC300lover
Thank you
yes new problem. Started last week after 2 year ownership. Immediately changed all batteries in remote
no USB charger in car
will check the phone issue you mentioned
Old May 29, 2019 | 10:17 AM
DennisMik's Avatar
DennisMik
My 2010 IS started doing that maybe a year ago and I haven't figured it out either. I can pick the fob up, put it down in the same exact spot and the car will start. I don't always have my phone with me and it still has the problem.
Do you know exactly where the sensor for the fob is? If it isn't too hard of a job, I might take it out of the car, pound it on the table a few times and put it back in and see what happens.
Old May 29, 2019 | 10:44 AM
ryanSC300lover
I don't know where the sensor is.
I am going to change to OEM battery, instead of AMAZON one today, to see if it fixes it. Will keep you posted
Old May 29, 2019 | 10:49 AM
2013FSport's Avatar
2013FSport
Center dash. Doors. Center rear IIRC.
Look in your manual. It shows the coverage. Antennas can be found in the parts diagram.
Old Jun 2, 2019 | 10:45 AM
ryanSC300lover
Just wanted to update
after replacing one battery $4 from toyota - all works fine
two battery from amazon ($5), were the culprit
Old Jun 2, 2019 | 08:14 PM
heidihidin's Avatar
heidihidin
sorry but are you saying that the fob battery is manufactured by toyota?
Old Jun 2, 2019 | 09:33 PM
nosurprise's Avatar
nosurprise
What are the voltages of the batteries you got from Amazon?
Old Jun 3, 2019 | 09:40 AM
ryanSC300lover
Amazon Amazon
This is what I purchased, that did not work correctly.
Old Jun 3, 2019 | 09:41 AM
ryanSC300lover
I am certain the batteries are not manufactured by Toyota.
The ones I purchased from Toyota dealer (parts guy installed it for me), works perfectly, with no issues. The one from Amazon worked, but exhibited the same symptoms as previous to the battery change.
Old Jun 3, 2019 | 08:44 PM
nosurprise's Avatar
nosurprise
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 This is what I purchased, that did not work correctly.
Right; I'm wondering what's the voltage when you measured them with a multimeter. Old batteries lose voltage.
Old Jun 3, 2019 | 09:32 PM
ryanSC300lover
My car oem remote was having issues
ordered on amazon
installed next day
issue continued
next day went to toyota dealer
New battery
issue resolved
complained to amazon
got refund
never measured anything
Old Mar 20, 2020 | 05:39 AM
benmunger's Avatar
benmunger
ordered on amazon
installed next day
issue continued
New battery
issue resolved
got refund
I have similar issues in my convertible. I'll have to try Lexus next time.
