2008 GS350. Trunk won't Open with Key/Button
Old May 22, 2013 | 09:57 AM
fruitycups's Avatar
fruitycups
Default 2008 GS350. Trunk won't Open with Key/Button
Hi guys,
Searched and found lots of threads regarding this issue. I have a 2008 GS350 AWD. One day, the trunk stopped working. The trunk button next to the drivers seat doesn't work nor does the button on the key fob work. I already pressed the valet button in the glove box, so I know its not that. Everytime I try to open the trunk with the key fob, it'll beep but the trunk won't open. The ONLY way to get it open is to many insert the key thats hidden in the fob.
I read a couple of threads regarding this problem. Some say they went to lexus and was charged 1600 while others say they fixed it themselves.
One person said "They unplugged the wiring harness from the ECU (Electronic Control Unit? I guess). Once the harness was plugged back in the ECU reset and trunk works fine now. However they tell me it could happen again."
Where exactly is the wiring harness/ecu? Does anybody have a diagram that I could follow?
Another person wrote "Took it to Lexus and they told me it would cost over $1600 to fix. Found your post, opened the trunk to disconnect the cable to the ECU. It would require some dissasembly. Leaving the trunk open, I disconnected the main battery ground and waited 5 minutes and reconnected the ground. This also reset the ECU. I closed the trunk and now everything works fine again."
Where is the "main battery ground"? Is he referring to the same battery that you hook up jumper cables to? (stupid question i know) if so, how do I disconnect the main battery?
HELP!!!!! Trunk not working is very inconvenient. Mostly at night time.
Old May 22, 2013 | 01:04 PM
JSM1284's Avatar
JSM1284
Just try disconnecting the battery first. Yes, the battery under the hood.
Old Aug 2, 2013 | 12:14 AM
RA21825's Avatar
RA21825
i had same problem, theres a button in the glove box, press it IN to enabled the boot,
Its some valet safety security thing. i was freaking out cause i loaned my car to my brother and it wasnt working, i was about to rip in to him then i found a thread on here which explained it.
https://www.clublexus.com/forums/gs-...wont-open.html
hope it helps
Old Sep 23, 2013 | 05:53 AM
mjlexus's Avatar
mjlexus
He said that was already tried.
Old Mar 18, 2014 | 08:12 AM
alexisbois's Avatar
alexisbois
Default problem with trunk
I, i'll do my best in english. I have a gs 350 2008 and I have the same problem. After have been experience the problem for few week, I forgot my light open and my batterie was empty. Though, I had to boost my car. I got surprise when I saw my trunk open as a new one !! Conclusion, it is for sure linked to the batterie and probabely computing thing or somethinf whatever, dont pay money for this kind of problem that could be repair by accident. !!
however, my trunk open only for few month and the problem came back. so I gonna to try to disconnect my batterie. according to my last experience, I think I should work...
Old Mar 18, 2014 | 10:13 AM
burny's Avatar
burny
Could you try it in French, I might understand it better! LOL just kidding man, good job
Old Mar 18, 2014 | 11:23 AM
IXI187IXI's Avatar
IXI187IXI
theres a tsb for a trunk release issue. check here
Old Nov 9, 2019 | 10:11 PM
Bernies's Avatar
Bernies
Default Trunk won't open for 2007 GS350
I had this issue.
I was cleaning the car and after I was done, the trunk refused to open unless with the metal key.
I later discovered that it was the valet botton that I mistakenly pressed. This deactivated the trunk.
I hear it's a safety thing when or if u have valuable in the trunk and u are releasing d car to someone else
Old Aug 4, 2021 | 12:07 AM
oceans's Avatar
oceans
About 1 month ago the trunk failed to close when pushed down so the auto closer engages on my RX450H 2013. Checked the Valet switch and that was ok. The boot light showed up on the cluster display. I took the negative terminal off the battery for about 30 seconds and that reset everything. But I have to set up a few things after that was done including the programmable seats. The trunk worked again. Last week the trunk had the same problem. I can get in with the key but not the fob or internal button on the driver side. Obviously not the fuse is not a problem because everything was ok until the second time. Valet switch is ok. The trunk light is still displayed all the time. Actually if the trunk is open with the key I have to close it like a normal trunk. The auto closing doesn't work.
Old Aug 9, 2024 | 11:56 PM
ru03's Avatar
ru03
2nd gear
Default Need help have similar issue
Hi everyone, I’ve had an ‘09 GS350 for about a year now. When I bought it, the previous owner mentioned that the trunk only opens with the key and doesn’t respond to the button inside the car, the key fob, or even the pad on the trunk itself. The strange part is that you can still hear the motor or actuator working when you try to open or lock the trunk, but it just won’t open unless you use the key directly. I’ve already checked the valet button, but that didn’t solve the issue. Does anyone know what the problem could be? Any help or ideas would be greatly appreciated.
Old Aug 10, 2024 | 06:05 AM
mcomer's Avatar
mcomer
If you are hearing the actuator but not getting action, consider cleaning/adjusting the striker. Test by pressing
the fob button when the trunk is already open and see that the action works when not touching the mating loop.
Old Mar 23, 2026 | 10:44 PM
highhhrider's Avatar
highhhrider
7th Gear
I had the same problem today. Thought it was a bad ground then came across this thread. This save me so much time.
pressed that little button in the glove and the trunk started to open again.
Old Apr 27, 2026 | 08:58 AM
Lexoanswers's Avatar
Lexoanswers
2nd gear
Default Same
was dropping my son in law off at work. And trunk would only open with key fob tried disconnecting battery, fuses. Nothing works heard gs350 has faulty trunk actuators so this will be my next step. Also tried valet button now this is causing my battery to drain
kaotiq
Feb 20, 2022 01:32 PM
lexman52
May 2, 2020 12:45 PM
attimus02
Aug 27, 2012 06:58 AM
ekim
May 1, 2011 10:23 PM
Jackalope
Dec 8, 2008 01:19 AM
