So we're in a recession, and i don't want to spend 20 bucks on an oil filter...so i did some research and i THINK that the oil filter found in an IS F is the same filter used in a Toyota Tundra 5.7L....Part Number 04152-YZZA4...but it only costs 5.41 from Toyota....
Anyone know if this is true? I bought the Toyota part but i haven't gotten under my car to see if it's the same...
mine cost 10 bucks at the dealer! a lexus dealer.? where did you get 20 bucks from? sell the F! recession? wow! i would never buy a car i could not maintain! meant nicely!
$20 seams too high but $5.41 is definitely much better ..... I'll be checking that out for sure. Thanks,
C.
Purolator specifies the same filter element for a range of Lexus V-8s including the IS-F, but if you go to a site where you can search parts by part number and use the same part number for the other V-8s (04152-YZZA4), you will not find a listing for the IS-F, only the LX470.
I buy filters in a box of 10 because it's cheaper. There is a dealership selling the LX filters for $3.99. I've not seen cheaper, but it may well be out there.
the F uses a cartridge style filter...so not your typical twist on filter. Anyways, bought the filter for the Toyota Tundra 5.7 V8 and it works fine....identical product.
I bought the filter for the first time at Lexus of Westminster because i didn't know any better.... Just sharing the info!
My car is happy now...new filter + mobil 1 0W-30 full synthetic
where did you get this price i looked and it is $7.77 for filter without shpping and tax.
Go to the link i posted and search for part #04152YZZA4 (bottom of page, in part 2 "Search by factory part number"). Price is $3.73 with shipping $0.37.
I bought the Purolator filter at Advance Auto the other day and tried to install it. No dice.
You can see how much more the Purolator sticks out of the housing in this shot:
When I pushed the Purolator down on the center tube, I found it binds on the outer diameter before it gets deep enough in the housing. I'm glad I had a Toyota filter just in case. Here's a side by side shot:
I also bought a funnel at Walmart I think many here will appreciate. See below:
It comes with a valve and a clear plastic hose so you can measure the fluid before you put it in, but if you unscrew the valve, the threads on the funnel allow you to screw the funnel right into the opening for the cap so you can pour as fast as the funnel will drain (pretty fast!) without spilling a drop. It works great and cost less than $4! It will work on most Scion/Toyota/Lexus vehicles too.
