Fuel reserve fix..TSB inside
Saw this on FB. Surprised it doesn't apply to the 2026 models as ours is a bit conservative also and goes to zero when there's still quite a bit left in the tank...
EDIT: I hate how FB likes to put their own link, didn't notice on my phone, poster below has the direct link.
I think this 2026 TSB fuel gauge/warning light/range prediction update was already done on the 2026 TX500h models. I took delivery of my 2026 model year TX500h FSPL in November 2025 and have routinely put in 16-16.8 gallons when range indicated is ZERO and the low fuel light is ON ("REFUEL NOW"). I deliberately "ran it down" multiple times to see how the car behaved. It never had a problem, even on hills with low fuel.
The TX500h fuel tank is rated at 17.2 usable gallons by the SAE standard measuring method, which includes TWO topping-off stages after first pump "click off" (fast fill/slow fill/slow fill). So I believe the reserve on mine is only about 1.2 to 0.4 gallons (7-30 miles depending on driving) which seems pretty reasonable. On long highway trips over fairly even terrain I can achieve 400 miles in most cases (mountains being the strong exceptions) - which is acceptable - though I'm conservative on regular trips and usually like to refuel early - by 320-350 miles - with significant range still showing.
Bottom line to ME is - don't be afraid to "top up" the fuel tank - its how ALL cars fuel tank capacity seems to be rated - and some need the owner to go slow and top up more than others. My Gen II Toyota Sequoia and Ford Expedition were two cars that REALLY needed this - though my 2010 and 2023 RX350's also benefit but to a lesser degree. NONE of my cars has ever had a problem with me doing this. But it requires a little patience and finesses at fill-up time. I do NOT let the tank "spill over".
Note also that first pump "click-off" is highly variable and controlled by a non-precision mechanism that's affected by many factors, including manufacturing variance, temperature, etc. So don't expect every pump to fill the tank to the same level every time on first click off. I have to chuckle when I see Youtube videos rating the MPG readings on a cars dash by the fill method - after ONE fill. It really requires averaging over MANY fills to figure the calibration out precisely AND accurately. It turns out my TX500h MPG dashboard estimate is very close.
Has anyone had the L-SB-0010-26 performed? Has it improved the fuel capacity and driving range for the car? If so, how much improvement have you seen in fuel capacity and mileage? Thank you in advance for any input. We have put up with poor fuel range and capacity on our 2024 Lexus TX 500h F Sport. Lexus has kicked the can down the road acting like a wonderful fix was coming soon. It has been 2 years and I have yet to see this miraculous solution.
I suspect (but can't be sure) the large hidden reserve in earlier TX's may trace back to around 2020, when Toyota was criticized for insufficient reserve - leaving some people stranded when they pushed the limits of range too far. A buddy of mine had this issue with his Highlander (empty REALLY meant empty) and his was updated by TSB to "fix" the issue. Perhaps they went overboard in correcting this in future cars.
Whatever the reason, I suggest you get the TSB update, don't be afraid to top off your tank per the SAE standard method (look it up) and perhaps try running the car down from full to "Refuel Now" indicated to see how much it REALLY holds, before reserve. I did. The answer I got was 16-16.8 gallons. And I NEVER ran out of gas or had any warning lights/drivability issues, etc. Your car, presumably a TX500h, is not likely to be any different.
This is far better than driving a car you really despise because its gas guage is too conservative.
Regarding the TSB NOT referring to the 2026 TX500h ...
This might be it. Just afraid to run it too low as Lexus is recently having recalls being done on fuel pumps overheating and getting damaged on cars with the 2UR-GSE V8 like my IS500 from running the tank too low. CCN also rails against topping off the tank too much as it can damage the EVAP canister, but I'll try to 2 click method next time.
Never had an overheated fuel pump or charcoal cannister/drivability problem in my (many) cars, running and refueling them as I do. And it would be pretty silly if Toyota/Lexus allowed their cars to be seriously and permanently damaged by the topping off REQUIRED to completely fill their car's gas tanks to the specified usable capacity as arrived at by an SAE method that REQUIRES topping off. And any DECENT engineer who wanted to keep their job would also protect the car from a complete spillover - which WILL inevitably happen many times over many sales and many years - its a VERY predictable and common operator error - not good for the environment nor safe to do.
Regarding the fuel pump recalls on the following models:
- 2015–2022 Lexus RC (including performance F variants)
- 2016–2020 Lexus GS
- 2022 Lexus IS
zheka130
May 9, 2026 05:07 PM
whlkev
Aug 15, 2008 01:02 PM
