Convertible Top Failure Help
DESCRIPTION: ~|~BODY / INTERIOR / EXTERIOR CONCERN CONVERTIBLE TOP NOT OPERATING PROPERLY. CHECK AND ADVISE. ~|~ ~|~CHECKED AND INSPECTED FOUND B2757 ROOF OPEN SWITCH. INSPECTED REAR OPEN SWITCH FOUND DETECTION ARM SPRING IS BROKEN NOT ALLOWING TO HE ECU TO READ THE CORRECT POSITION OF THE HARD TOP RECOMMEND TO REPLACE SWITCH AND ARM ASSEMBLY
SERVICE:
DESCRIPTION:DECLINEDSERVICE: TOP SPRING ASSEMBLY
If anyone has some insight on what this Top Spring Assembly Switch & Arm is I would greatly appreciate it!
SERVICE:
Welcome to the Club and Congrats on your first post!!
Is it possible to call that Lexus dealership who wrote the notes and ask if they can interpret the notes better for you or was it the same dealership you asked?
I hope someone chimes in to offer help…
Once you get the OEM Part Numbers, I recommend going thru one of these online dealerships’ parts depts (if you don’t already know about them) — Bell Lexus (AZ), Treasure Coast Lexus (FL), or Prestige Lexus (NJ) depending on your locale. And if you can wait for next sales that are usually around holidays and seasonal events, you can save even more off their already marked down prices. You can always call and ask when next sales are.
* With Free Shipping and No Sales Tax for out-of-state customers.
https://parts.treasurecoastlexus.com/
https://parts.belllexusnorthscottsdale.com/
https://parts.prestigelexus.com/
A good resource I use to find specific Part Numbers is megazip — once PN is found you can search the PN in the links above.
Thank you for the warm welcome! And thank you for pointing out these dealerships for parts. I haven't owned a Lexus in about 10 years but have been itching to find my way back for a while now lol. I also didn't even think to call the specific dealership it was serviced at, I just called my local Lexus and they tried but couldn't quite figure out what it meant. I will reach out to the CA dealership on Monday and see if they can help me out further! After doing as much searching as I could handle in an afternoon I found a similar scenario referencing the hinge mechanism in the top itself and calling it the "Top Arm Assembly" so I am thinking it might be one of those. I visually inspected and don't see anything that appears out of wack while the top is closed so I'm going to manually open it today and have a better look.
No worries. I wonder if this might help you find the specific part you’re looking for.
https://lexus.oempartsonline.com/v-2...onvertible-top
If you get the PNs you need, you can always call Bell Lexus to confirm (they’ll ask for your VIN) — speak to Joe or Hayden as they are both knowledgeable and very helpful.
Thank you again!
Thanks so much @DshngDaryl‼️
OP — I quickly looked at all the websites I provided you above, and the part says Currently Not Available on all the websites I tried to find. Then I tried Google and came up with this one off eBay. Of course it’s used, but hopefully still works and can help you.
This is the Part Number:
PACKAGE TRAY
Part Number: 6436024010C0and eBay link:
https://ebay.us/m/65fLry
Otherwise maybe Yoshi Parts, NENGUN, Amayama or car-part.com / https://www.car-part.com/, local salvage yards, or Facebook Marketplace might have one.
Good luck and please update this Thread along the way.
* EDIT: Forgot to include MegaZip
https://www.megazip.net/zapchasti-dl...308601-4308601
PACKAGE TRAY
So I got that bad boy out of the car! Its a pain in the butt but could have been worse I guess.
You can clearly see the arm is broken that pushes out the corner flap. The full pack I found on ebay came with the motor as well, I figure might as well replace that too since I don't know if it works or not!
I recognized that the cable from the motor to the drivers side wasn't doing anything other than spinning freely when I twisted it. So I removed the gear pack the cable connects to, to find the metal post coming out of the package tray & into the gear pack was sheared off! So I replaced it with the gear shaft from my old package tray, and it still wouldn't work! I found the other side of the new tray was getting bound up when the corner flap tried to come out. So I once again pulled the gear pack from the other side, and found it full of rust and corrosion. So I swapped the passenger side gear pack over and it worked! After removing the package tray a total of 3 times, I hope to never touch it again!
Awesomeness — So glad you were able to solve the issue!!
Your tenacity / doggedness paid off — Well done You 🙌
