2017 RX450h wiring connector behind cowl
Old 04-29-24, 02:30 PM
Velowine
4th Gear
Velowine's Avatar
Default 2017 RX450h wiring connector behind cowl
Can anyone advise on the system which would be connected to the wiring terminal behind the cowl at passenger side of the vehicle near the bottom of the windshield?
We had a new windshield installed and there was wiring connected at this terminal prior, but nothing was connected after the new windshield was installed. What did they miss?
Thank you,
Wiring terminal behind cowl passenger side after recent windshield install. Prior to new windshield, wiring was connected to this terminal and entended to base of windshield. What system does the serve?
Old 04-29-24, 03:21 PM
Received 2,743 Likes on 2,324 Posts
Probably cold area spec aka heated windshield.
Velowine (04-30-24)
Old 04-30-24, 06:09 AM
autotech13
autotech13's Avatar
Is there a connector near by?
Old 04-30-24, 06:13 AM
toyotaman7
toyotaman7's Avatar
It is possible that your car came with heated glass under the wipers and the new glass is missing that feature.
Check with Lexus of your car came with heated windshield which is typically part of cold weather package as @LeX2K mentioned
The following 2 users liked this post by toyotaman7:
autotech13 (04-30-24), coolbrazz (04-30-24)
Old 04-30-24, 11:09 AM
Velowine
4th Gear
Velowine's Avatar
Thank you for the replies. Will check the vehicle accessories installed, i.e. heated wiper button on the dash.
Old 04-30-24, 11:11 AM
toyotaman7
toyotaman7's Avatar
There is no hard button on Lexus.
If equipped it will be a sub menu under heating and ventilation menus in the center screen
Old 04-30-24, 03:36 PM
Velowine
4th Gear
Velowine's Avatar
Default Heated windshield icon in climate control display.
We found the icon to operate the heated windshield option as you described. Thank you for your help. Much appreciated!!
Heated windshield option. To operate, click the three bars to the right of this icon. Toggle feature on/off. Amazing option for snowy winter climates.
agarrido
10-25-22 04:08 PM
NorthernHi
NX - 1st Gen (2015-2021)
03-02-18 02:23 PM
uicandrew
ES - 6th Gen (2013-2018)
10-25-12 09:34 AM
e-man
10-01-06 10:26 AM
Quick Reply: 2017 RX450h wiring connector behind cowl
