Shaky at 60
I have gotten a lot of useful help here, in the 9 years of owning a 2002 SC430. One thing no dealer inspection, test drive or align/brake service has solved is kind of annoying.
The vehicle has a visible shimmy at or around 60mph ONLY when the car is first driven from full cold. I have replaced tires, had wheels brought true out of round, alignments, suspension and ball joint/control arm replacements over the years. NOTHING stops it, except of course for driving 2-4mph, at which point it doesn't really show. The only time outside that time/warmup distance that it has shown once or twice was while switching lanes under acceleration, same rel. speed range. I can only assume it is a NON tire/wheel issue, and novice as I am, have absolutely no idea what other component could simply be 'warming up' on the first run of the day (car isn't used for track, just concerned showing it to a buyer might make it appear sloppy)!
Are there any components that might cause this only when they're warming up? Power assist steering? Bushings of some kind?
I don't wanna spend thousands figuring it out, but it is weird!
I've had a slight shimmy at 55-60 mph forever. It was slightly worse with OEM wheels and slightly better with my after market TSWs. I just try not to drive at those speeds. One thing about shimmys that go away after the car warms up - if you have flat spots on the tires due to being on a cold flat surface, after the tires warm up the shimmy usually goes away. Been the case for me with most of the cars I own anyway. I just let it be. As long as the old girl cruises well at 90 mph after she's all warmed up, I am good.
I did a search on YouTube and came up with these videos for u.
https://www.youtube.com/results?sear...r+shimmy+at+60
I think this one may be best for u
I thought only mine does that. I, too, have this issue when the car is hitting 55-60 the first few rounds, and it goes away after that. It happens regardless if the car is cold or after 10-15 mins of lower-speed driving. The shaking also goes away at 65 MPH, but it shakes again when going back to 55-60. I would suspect the vibration will get worse as it goes faster, but that is not the case
My only concern is, since it's not tires/wheels/other moving parts afaict....then what is a part of the steering or suspension I would say it's "about'......as I think w.o a tech qualification as to the source, I might be opening up a can of buyer concerns of huge component repair issues?
this thread (link) describes numerous causes and remedies. Lighter wheels may help. Also all maintenance has to be done regularly: alignment, balance, tire inflation, bushings. This car likes to be maintained, not neglected.
I can't confirm or deny anything other than OEM wheels, and I'm laughing at Santa Clause thinking anybody else would be a ocmplete fool to just go buy lightweight wheels for a check over of the suspension and all other stuff...ain't gonna happen.
There was one writer above who said he'd the same issue...but his was regardles whether car is warm or cold. My GUESS is its something in the steerinp pump which doesn't do full pressure in the lines until car has warmed, but then, you'd probably have inreased steering effort?
-What about he Flying Dutchman from Spongebob? Wouldn't he have the answer on these ships..."Aye, kiddies are you ready yet? I can't STEEER you?!"
Well no one is telling me this sounds like a safety issue....yet....>AAAAAGGGGH! Happy halloweed!
NoobExe
Jul 15, 2021 11:04 PM
derukun
May 16, 2021 03:18 PM
loveslexus
Oct 21, 2013 04:14 AM
