Window switch
Old Jun 24, 2022 | 01:37 PM
wcarr8888's Avatar
wcarr8888
Default Window switch
Hi everybody
I have a 09 pebble beach
‘passenger window goes up and down when top opens and closes
passenger window goes up and down with passenger door switch
‘passenger window will go down but not up with drivers side switch
has anyone else had this? Maybe a bad switch in driver’s door
how hard to change
thanks a lot
Old Jun 25, 2022 | 02:53 AM
Bgw70's Avatar
Bgw70
Veteran: Air Force
Originally Posted by wcarr8888
Hi everybody
how hard to change
thanks a lot
I have never had this problem.
if you have a multimeter, you could ohm out the switch to know for sure.
the switch is easy to change.
Old Jun 25, 2022 | 05:11 AM
iolmaster's Avatar
iolmaster
Hi everybody
how hard to change
thanks a lot
I had a very similar situation. I changed the switch and it did not fix the problem. I then changed the door window/lock controller (the computer inside the door) and it fixed the problem. I got the door controller used on ebay for about $40.00. BGW is correct however, the switch is very easy to change. Just pry up the one in the car now and unplug and reverse. Ten minutes max. I could not find a used switch and bought a new one for $239.00.
dany916
IS C
Jul 8, 2025 10:38 PM
GS430Blue
Aug 20, 2021 10:25 AM
jspringato
Jul 16, 2021 07:09 PM
RonCon
RX - 4th Gen (2016-2022)
Jun 7, 2021 02:54 PM
ldysrvyr
GX - 1st Gen (2003-2009)
Sep 16, 2020 03:26 PM
