Lumbar support problem
Old Feb 16, 2022 | 10:26 AM
Cinc04's Avatar
Cinc04
Default Lumbar support problem
I've got a 2004 SC430 and the lumbar support, for the driver's seat, has never worked since I purchased the car a couple of years ago. Since I had some extra time, I thought I would investigate. I pulled the seat side cover off and found that the connector, to the lumbar switch, had been disconnected.
I don't think it just fell off and I would assume that someone disconnected the switch. Maybe it was disconnected because either the switch or motor is defective and when you hit the button, you blow a fuse. Any thoughts?
I am going to pull the seat out so I can get to everything a little easier. I read some posts and it appears that you remove the 2 bolts at the rear of the seat rails, move the seat forward and then remove the 2 front rail bolts. Disconnect the battery and then lean the seat back and disconnect the wiring connections. If I have missed something, please respond.
I see that there are replacement lumbar motors and switches on eBay.
Thanks for any assistance.
Old Feb 16, 2022 | 03:28 PM
Raven01750's Avatar
Raven01750
I have never heard of one of those motors going bad yet. The only real seat issue I am aware of is the seat heater relay goes out causing the heater light to stay on. Plug it in, test it and go. Good luck.
Paul
VroomSC430
Dec 28, 2025 12:59 PM
Lysmau
Feb 19, 2024 03:09 AM
Raven01750
Jan 26, 2024 08:24 AM
plumbstar
RX - 1st Gen (1999-2003)
Jan 12, 2010 04:20 PM
shajbot
Feb 2, 2009 05:57 PM
