Oil changes, etc.
Hi all
Some 5,500 miles ago I bought my '07 SC at which time they did an oil change, resetting the maintenance required light at the same time.
The maintenance light is flashing for a brief time time after startup, so I'm assuming it's time for an oil change.
This brings up a number of questions:
- What is typically the mileage between indicated oil changes? 5,500 miles seems a bit early, but what do I know?
- Has anyone ever mounted a Fumato valve to their SC? I've got them on a couple of other cars and like them a lot.
- Where's the best place to buy oil filters?
- I did a quick pretrial through the "maintenance" section in the onboard navigation system. It's it me, or is this perfectly useless?
I'm NOT an oil expert.
Factory recommends every 5K
I prefer OEM filters. Oil filters cans be (typically) sourced cheaper from a Toyota Dealer - part number 90915-20004
Haven't put a Fumoto valve on my SC but have an extra one that may go on at next oil change. Need to check how low it will extend.
I change my oil between 4K-5k miles and use synthetic
oil filters are Toyota purchased online, usually from Amazon, Rockauto or eBay. Will look for the best deal on 8+ Filters…then only need to purchase every few years.
I also buy my oil in 5 quart jugs when Mobile1 has a rebate. You used to be able to get 5 quarts of full synthetic from walmart for $25 (before rebate), but now with inflation going crazy, I have no idea how much it is now
Thanks all.
Appreciate the feedback.
5k seems fairly frequent. My Honda's have some sort of algorithm, I guess based upon usage and mileage and it was typically between 7,000 and 10,000 miles. Oh well.
I need to look under the car to see if a Fumato valve would be the lowest point. That would be sub-optimal.
I'll order a bunch of filters online and a filter wrench if I don't have one.
cheers
cheers
Went to buy oil filters at Toyota Parts Now and there was an $18 shipping fee on top of the $3.77 per filter for a quantity of 8.
I'll check a local dealer. If they can beat the $6.02 net price, I'll go that route....
Cheers
Cheers
Looks like u can buy them for $6 off amazon
https://www.amazon.com/Toyota-Genuin...s%2C108&sr=8-2
But you may want to pay a little more for the Oil Plug gaskets & filters combined
https://www.amazon.com/Toyota-Genuin...s%2C108&sr=8-7
Since it would take me several years to use 5 of them, I just buy them from the dealer as I need them
I reset my 08’s oil warning light ls 460 at 5k miles. Went to 10k oil change intervals like the identical later model ls’s use.
i do top up the oil with 0-20 TGMO i have a quantity of in between the changes.
The upside of the Fumoto valve is apparent, but consider the cons: the threaded portion that goes into the pan prevents complete draining; the valve typically hangs lower than the rest of the engine, which makes it prone to being hit by road hazards; an enemy could drain out your oil with minimal time and effort (not that I'm paranoid or anything); it's one more part that can malfunction vs the drain bolt. Overall, the benefits don't outweigh the risks.
The latest/greatest deal in synthetic oil is Costco's Kirkland brand. It was tested by Project Farm and performed admirably. Ten quarts costs $39; comes in a case of two, five-quart jugs. You gotta love the huge jugs!
Wow,
Got the oil changed. I don't think I'm going to worry about the Fumato valve.
The filter is a pain in the ear to get to. The drain plug is a piece of cake in comparison.
To get to the filter, you have to remove at least one bottom panel. I took both bottom and side off, but might try just the bottom next time
Yikes.
Any suggestions on how to avoid getting oil all over? I only marginally succeeded this time.
Yikes.
I am the 3rd owner of my SC430. One of the previous owners (or a Dealer or repair shop) actually cut a section of the plastic lower engine panel out to provide oil filter access. While I probably wouldn't have done that, it does make things pretty easy.
