Lexus sc430 Rear lights do not light
Old Jan 3, 2022 | 06:59 AM
Konrad12's Avatar
Konrad12
Default Lexus sc430 Rear lights do not light
Rear lights do not light I checked the fuses through all the current flowing so they are ok. I drank and plugged in the plugs and still nothing.
Old Jan 3, 2022 | 10:21 AM
GmanSC's Avatar
GmanSC
Konrad,
Like we stated on the other thread of yours, you have problem with your contacts in the harnesses. You need to locate the connectors for the lights and clean them or replace them. Someone please post the lighting diagrams to help Konrad out. I think he’s chasing his tail.
Old Jan 3, 2022 | 01:26 PM
Wilson2000's Avatar
Wilson2000
Sounds like your problem is a grounding issue if more than one light isn't lighting. Plus, you said there is current flowing to them. Check the ground for the lights, where it bolts to the body/chassis. Or, as Gman said, at any connector in the lighting harnesses.
If I owned a flooded vehicle, I would disconnect, clean, and re-seat every harness connector on the vehicle, after applying a healthy dose of di-electric grease. I would do the same for every ground connection to the chassis.
C0nn0r91
Mar 5, 2022 12:22 PM
KMGradev
Oct 6, 2021 04:00 PM
Anks8040
NX - 1st Gen (2015-2021)
Dec 27, 2019 09:11 PM
FergzSC430
Sep 15, 2019 08:18 PM
goodsonp52
Jan 13, 2018 11:42 AM
