Warning Lights
Old Oct 5, 2021 | 03:52 PM
KMGradev's Avatar
KMGradev
Default Warning Lights
Hi guys,
I was wondering if someone has had experience with the warning lights coming on on their Lexus SC430. At present the VSC light and the Brake Warning lights are constantly on. The car drives just fine, though. Do you know what might be causing the problem? Any advise would be highly appreciated.
Thank you very much in advance.
Old Oct 6, 2021 | 08:02 AM
NEWONE1's Avatar
NEWONE1
See if the paper clip zero calibration procedure will clear it....many threads on this subject....good luck.....
Old Oct 6, 2021 | 09:15 AM
mandyfig's Avatar
mandyfig
Paper clip should clear this and the see what happens. Good luck.
Old Oct 6, 2021 | 09:37 AM
oneround's Avatar
oneround
I have made more than a few dumb mistakes, and just in case the OP does as well....
The brake light: Parking brake is off, and you have checked the brake fluid level?
The VSC light: Is the switch on the console in the off position?
Those are the kind of things I've done in the past. Actually, I've done a bunch of even dumber things.
Old Oct 6, 2021 | 04:00 PM
Bgw70's Avatar
Bgw70
Veteran: Air Force
Looks like he has a problem with the brakes…the VSC may not clear until the brake light is cleared.
Looks like a 2002, right hand drive, based on the photos.
he also might have a flat tire or bad TPMS sensor(s)
Klauss
RX - 1st Gen (1999-2003)
May 7, 2021 11:19 PM
dawson5555
Aug 25, 2010 02:15 PM
jonahb
Maintenance
Mar 25, 2008 09:56 AM
parula
Feb 20, 2004 10:03 PM
