Resurrecting 2003 SC430
Old Dec 5, 2021 | 07:37 PM
oneround's Avatar
oneround
Bumper: On an older Land Cruiser with a plastic rear bumper one side got torn loose on a rock. I was able to get a screw through the bumper near the mount, and then used J-B Weld to affix the mounting bracket of sorts. Used some body putty made for plastic bumpers along with a bit of touch up paint. Looking at it from the underside, obviously not stock, but from an external view it was fine and held up for the few more years I owned it.
VSC: Not sure how this system works, but I know the wheels have to be pointed straight ahead when one does the reset.
Old Dec 6, 2021 | 05:59 AM
voloc22666's Avatar
voloc22666
It might be the VSC is still related to my CEL, due to the O2 sensor needed to be changed. this is bank 1 sensor 1, that failed, not sure if i can do it myself without breaking it off...
Old Dec 10, 2021 | 07:29 AM
voloc22666's Avatar
voloc22666
So instead of going under the car i decided to go to the shop to change O2. "Few bucks" as they promised on the phone turned out to be $125. No special tools were used and i doubt they applied the grease onto the new one, but i guess this sensor will die with the car anyways..so lights are gone, both vsc and cel.
got the replacement rear height sensor, will have to chase the threads, since i broke off the bolts and drilled new holes.
leather is coming in today, but i screwed up when cutting off the heater pad from the back of the driver seat, have to fix it
Ftpbandit
Apr 21, 2026 06:35 PM
WeekendDIY
Oct 27, 2022 06:21 AM
HobieMarty
RX - 1st Gen (1999-2003)
Oct 7, 2019 09:56 AM
dredkam
Apr 11, 2018 05:53 AM
Eagleguy
May 10, 2013 10:21 AM
